just updated to latest 3.2 but user cannot sort by timestamp in interface
i see that there is limitations but wondering how can we find a workaround ?
Thanks a lot
Thanks a lot
Anyone has a workaround for this ?
he @jothoma1
which bug-fix release did you use?
the latest include the ability to sort for different data rows - because the default is the field “timestamp” I assume that you have a different field with a timestamp?
Hi @jan
we are in Graylog 3.2.4
and nope it is with the field timestamp when we click on the field we have a menu like this (see below) but no ability to sort ?
Ok found my mistake… so the menu for sorting is now on the right …
Thanks @jan !!
