Hi Folks,
We are using Graylog 3.2.0-beta.2+18766e8.
But I can not find the “sorting” and “Show surrounding messages” functionalities when searching messages.
Please, do you know if these features were removed from this version?
currently that is not (yet) given. If that will not make it into the GA Release that will be added in the next releases.
Thanks @jan.
Maybe I should go by V3.1.2 version. Please, do you know if V3.1.2 release provides these features?
I guess you messed around with the version numbers … the search will be fundamental changed in 3.2 - before (3.0 and 3.1) it was the same as with 2.4
Ok, got it.
Thanks @jan
Hey @jan can you please elaborate on this answer? I am new to Graylog and one of our system admins updated graylog to version “Graylog 3.2.0+4edc81f” today. I can no longer find the “Show surrounding messages” feature which was extremely useful to locate bugs.
Can you let me know which version I should revert back to (in order to get this feature back?)
he @photogrey
as you can see in the upgrade notice: https://docs.graylog.org/en/3.2/pages/upgrade/graylog-3.2.html#known-bugs-and-limitations
This is currently not given, but will be re-implemented.
You can only return to the previous version if you have made a backup of your MongoDB before you upgrade as downgrade is not an option.
