When upgrading (migrating) from GL 3.2 to GL 4.x where is the existing Sidecar token? At the moment all Windows sidecars show inactive with no pings. I see documentation for upgrading from older GL to 3.x. But I don’t see documentation for going from 3.2 to 4.x. And interestingly, they are ALL still sending logs, so it’s the config management that’s gone. As if the api token is working, but you can’t see it from the GUI.
Hey there, see my reply in your other post here No Tokens seen anywhere? - #3 by aaronsachs. You should be able to see sidecar tokens there.
