Went from 4.x to 5.2.4 and sidecars are no longer talking
All my sidecars say unknown. Sidecar user not logged in.
  • OS Information:
    Ubuntu 22.04
  • Package Version:
    Graylog 5.2.4
I restored the mongodump from the 4.x environment and everything seems to be working but the sidecars. All the sidecar endpoints are logging but the sidecars aren’t connected where I can manage them.
Any suggestions or insight would be appreciated.
You could try generating a new API token and applying that to one of the sidecar configs and see if it starts up again.
A new token worked. I added it to all the endpoints. Would be interesting to know why the old one stopped working but not necessary.
Thanks a million.
This could be a cert issue. Are you using a cert for your graylog server? If so, did you put it in the truststore after the update?
Greetings
Only with nginx to do the reverse proxy. I haven’t specifically put anything within GL itself.
