Hi there
Is there an option to remove “old/inactive” sidecar collector instances?
E.g. WindowsServer 83399xyz… — inactive
thanks!
Hi there
thanks!
he @afmin
did you use the legacy sidecar or the new?
Because both should have inactive removed after some time.
Hi @jan
Not at all. They are still there. Its now some days ago.
I am using graylog_sidecar_installer_1.0.2-1
he @afmin
what version of Graylog did you use?
He @jan
I am using GL 3.1 I just started the configuration some days ago.
Moin @jan
Is there an option to delete them manually?
Ty!
