Hi there!
I just was wondering if is there any way to export all the Graylog configuration in a JSON file, I just need to move a current Graylog that was deployed with helm to another Kubernetes cluster. my idea is to export all the Graylog configuration to a JSON file and put it in a Configmap.
The Graylog config is housed in the mongodb instance (default graylog). So it should be doable via mongodb commands. But I’ve never done it so this would be where my advice ends.
Thanks for your reply, I was thinking to try with helm hooks to be able to run mongodb commands after graylog helm chart installation…I will share my findings with the community
