Export and Import Graylog configuration
Hello World,
I am currently carrying out graylog integration tests within my company.
We might be likely to switch to the enterprise version of graylog in the near future.
I performed configuration tests on a server with the Ubuntu 18.04 OVA.
I would now like to be able to export my configurations (Dashboards, Streams, Alerts) on my future server in Production which is based on CentOS 8.
I tested the export of the “views” collections, without success.
For convenience, I also tried to install the plugin provided in the Graylog Marketplace, also without success. :frowning:
Isn’t there a simple way for save your configuration to restore it or export it to another server?
Thanks for your help
Mathieu
You could create a content pack for yourself
https://docs.graylog.org/en/latest/pages/content_packs.html?highlight=content%20pack#content-packs
I have just moved my Graylog from one ubuntu installation to another. I followed this guide
Four main things to do
  1. Data base dump / export
  2. Export / copy graylog config file to new server
  3. Export / copy node_id_file to the new server
  4. Date base import
Also if your using TLS dont forget to import your certs to the java key store.
I found, as the default installation has the sidecar user already I had to delete it and re-import again so I didn’t lose all my authentication tokens, I also had to add the admin role back to my admin users.
Export / dump command used
mongodump --db graylog --out /home/username/graylog_backup
Restore command used
sudo mongorestore /home/username/graylog_backup
Good luck
