Goal: Lookup DestIP (IP address) at greynoise and append log-entry as an attribute.
Problem:
Rule never find any matches for the field DestIP - not even during rule simulation. Attached shows the situation. The simulator claims the field “DestIP” doesn’t match as far as I can tell. But it is clearly there if you loook at my screenshot.
The reason I know that it is the IF test failing, is that I tested by removing the IF test, replaced it with a value that always was true and then it appended something to the entry in the simulator.
Could there be I need to use another field instead of DestIP? Or is it something wrong with the formatting in the textfield?
On the test lookup-page inside graylog, it shows the expected result queried, so nothing wrong with lookups.
I’m using pfSense and logging to graylog. I used a cheating set from Lawrence Systems to get the input-values into DestIP and all the other values.
Rule Simulation (greynoise doesn’t appear as a tag unless I remove the IF test):
Graylog 5.1.7 (Eclipse Adoptium 17.0.8.1 on Linux 5.14.0)
