Pipeline value to extract
Hello guys,
I am trying to extract the values from here and add use them as ip enrichment. I am interested in “harmless, malicious and suspicious”.
“single_value”: “GOOGLE”,
“multi_value”: {
“harmless”: 65,
“malicious”: 3,
“suspicious”: 0,
“undetected”: 21,
“timeout”: 0
“string_list_value”: null,
“has_error”: false,
“ttl”: 9223372036854776000
My current pipeline rule is looking like this :
rule “ip check”
when true
let harmless = lookup (“virustotal-table” , $message.dstip);
set_field(“harmless_score” , harmless);
Please let me know what i am doing wrong, because is not working. I am receiving a null result.
Thank you.
Try this:
rule "ip check"
  has_field("dstip")
  let virustotal = lookup (“virustotal-table” , to_string($message.dstip));
  set_fields(virustotal);
Or this:
rule "ip check"
  has_field("dstip")
  set_field("harmless_score", virustotal.harmless);
  set_field("malicious_score", virustotal.malicious);
  set_field("suspicious_score", virustotal.suspicious);
If it doesn’t work, check for errors in server.log.
Pretty much the same question only the (json) output is a little different:
“single_value”: true,
“multi_value”: {
“value”: [
true,
“+0123456789”,
“MOBILE”,
31,
“NL”,
“Netherlands”
“string_list_value”: [
“true”,
“+0123456789”,
“MOBILE”,
“31”,
“NL”,
“Netherlands”
“has_error”: false,
rule “number lookup: dnid”
has_field(“dnid”)
let number_lookup = lookup(“phone_number_lookup”, to_string($message.dnid));
let type = to_string(number_lookup[“type”]);
let country = to_string(number_lookup[“country”]);
let country_code = to_string(number_lookup[“country_code”]);
let country_name = to_string(number_lookup[“country_name”]);
set_field(“DNID: country”, country);
set_field(“DNID: country_code”, country_code);
set_field(“DNID: country_name”, country_name);
set_field(“DNID: type”, type);
If i add “debug(lookup(“phone_number_lookup”, to_string($message.dnid))); "
It returns in logs this:
{value=[true,”+0123456789",“MOBILE”,01,“ZZ”,“Somewhere”]}
So the lookup works
How to get the correct values?
Answered my own question:
For anyone else: (It’s working now)
Here’s the original json output:
{“isValid”:true,“phoneNumber”:“+01234567890”,“type”:“MOBILE”,“country_code”:31,“country”:“NL”,“country_name”:“Netherlands”}
Single value in data adapter becomes:
$.isValid
Multi value becomes:
Now when testing the lookup reads:
“multi_value”: {
“isValid”: true,
“phoneNumber”: “+1234567890”,
“type”: “MOBILE”,
“country_code”: 31,
“country”: “NL”,
“country_name”: “Netherlands”
“has_error”: false,
Now in pipelines I can do:
set_field(“DNID_country”, country);
And works.
Yes, worked. Thank you.
