Simple Pipeline Rule
Trying to work towards an enrichment via a lookup table. However I cannot seem to get a pipeline rule to work at all.
I have a working system, with a stream, and extractors running on the messages to parse the messages into fields… These are syslog-like messages.
  • OS Information:
    Ubuntu 22.04
  • Package Version:
    Graylog 5.0.8+4c22532 on sparc-log01 (Eclipse Adoptium 17.0.6 on Linux 5.4.0-150-generic)
I followed the documentation to create a lookup table, and connect / create a pipeline and a rule .
I can use the test in the lookup table and get desired results.
Basically what I am trying to do, is take a field, field_a that is already present in a log message (created by an extractor), and use it as the key for a lookup table, to then set a new field in the log that contains associated data (the value from the key->value lookup table query).
However I cannot even get the pipeline rule to work… I created the following rule as a test:
rule “Add MemberSEP”
1
set_field(“membersep”, “unset”);
This does not work. I even tried using the debug() function to see if I could get more info but could not get any log messages into the server log.
The real rule would look like this:
has_field(“calix_severity”)
** lookup code to add new field with value **
I would think the test rule should create the new field in the log message and set it to a value of “unset”
I am stumped,… have scoured the forums and web tyring to find a clue…
Any advice or direction is appreciated.
Sounds like pipeline is running before extractors. You would need to change the ordering of processing stages so pipeline runs after message filter.
thought I had done that… This is how its currently configured.
Also, I do need the extractors to run first, as they are creating fields in the logs that I need to use to process in the pipeline.
It looks like your processing order is correct. ‘Message Filter Chain’ is the processor that handles static fields and extractors. However, it looks like you have stream rules AFTER pipeline processor. This means that if you are using stream rules to route messages, the pipeline processor will have zero knowledge of what stream the message is in.
You can address this by either using pipelines to route messages to streams, or change the order.
For your test pipeline, you can use true for a condition that is always matched:
rule "test rule"
    true
    set_field("test_field", "hello world");
The pipeline simulator may also be useful:
  1. copy any message from the search page using the ‘copy message’ button
  2. go to System / Pipelines / Simulator
  3. Paste the copied message json
  4. Choose stream to suit your needs
  5. set message code to gelf
Hope that helps.
I am going to try this, I am indeed using stream rules.
I will change the order and test again, as well as investigate changing to using pipelines to route. Any side-effects I need to watch out for when changing the from stream rules to pipelines?
Alright, I changed the order, and used the simulator to check a message…
These are the results.
27 μs
Starting message processing
5,110 μs
Message 7bd11900-3579-11ee-b3bf-3a1313377832 running [Pipeline ‘Calix_UPN_Enrichment’ (64cb19be214be969cc9e4c1c)] for streams [620c50407ad02700aed067e5]
6,720 μs
Enter Stage 10
6,926 μs
Evaluate Rule ‘Add MemberSEP’ (64cb1f6d214be969cc9e586a) in Pipeline ‘Calix_UPN_Enrichment’ (64cb19be214be969cc9e4c1c)
7,116 μs
Evaluation satisfied Rule ‘Add MemberSEP’ (64cb1f6d214be969cc9e586a) in Pipeline ‘Calix_UPN_Enrichment’ (64cb19be214be969cc9e4c1c)
7,298 μs
Execute Rule ‘Add MemberSEP’ (64cb1f6d214be969cc9e586a) in Pipeline ‘Calix_UPN_Enrichment’ (64cb19be214be969cc9e4c1c)
7,607 μs
Finished execution Rule ‘Add MemberSEP’ (64cb1f6d214be969cc9e586a) in Pipeline ‘Calix_UPN_Enrichment’ (64cb19be214be969cc9e4c1c)
7,839 μs
Completed Stage 10 for Pipeline ‘Calix_UPN_Enrichment’ (64cb19be214be969cc9e4c1c), continuing to next stage
7,983 μs
Exit Stage 10
8,056 μs
Finished message processing
However, I do not see that the log entry was modified to include the new field. Would I not see this in a search? Ultimately, the goal here is to use this modified version of the message for a notification sent from Alerts and Events.
This is my pipeline rule: (basically following this simple example: How to Use Graylog Lookup Tables )
rule "Add MemberSEP"
    has_field("ont-id")
    let sep_source = lookup_value("AccountName", $message."ont-id");
    set_field("membersep", sep_source);
I quote the ont-id part of the field, because i get errors when trying to use it otherwise. That could be some of the issue, but changing the defined name of that field is not feasible in our scenario.
And nothing I try, (escaping the - or quoting around it, can make it work.
How do you deal with special characters in a field name? I can find all kinds of things for GROK patterns, etc. But none of that works in this case…
The - is fine the the has_field() function, but doesn’t work in the others… ie. in $message.ont-id or sep_source.ont-id
    has_field("ont-id")
    let sep_source = lookup_value("smx_sep_lookup_table", to_string($message.ont-id));
    set_field("membersep", sep_source.ont-id);
I resolved the issue…
It turns out there was some simple errors… The lookup table name was wrong for one…
Corrected that, and then the quotes around the field name worked.
ie:
    has_field("ont-id")
    let sep_source = lookup_value("smx_sep_table", $message."ont-id");
is working. Sorry for the confusion, and thanks all who helped.
