Graylog Advance Rules and Dynamic Lookup
Hello Team ,
I am using graylog for last couple of months and feel like graylog is lacking on following points :
  1. Can it possible to have dynamic lookup table instead of static lookup , so that field can be added into lookup on the fly.
  2. Multi-correlation for heterogeneous devices based n srcip or usernames like commercial SIEM have nowadays ?
  3. Can you used lookup table in the rules?
I am facing challengers in creating some advance rules because of above point. Let me know if its possible to such flexibility in graylog.
Thanks,
#1 I’m not entirely sure what you mean by “field can be added into lookup on the fly” - if you mean you want to populate a lookup table using data from Graylog, then that isn’t possible.
#2 Also not sure - got an example?
#3 Yes, you can use a lookup table in pipeline rules (via the lookup function)
Thanks,
For point #1 and #2 , is there any roadmap for such features ?
For point #3 , I mean can we used lookup table in Alert condition ?
#1 there is no such plan to do so in the future. But feel free to open a feature request at github with example usage.
#2 I also would need an example to understand what you want to achieve.
#3 The lookup table is used to enrich your data. For example, you can tell via Tor lookup table, that a source IP is from a TOR exit node and you can mark that in your pipeline rule. And than you can decide in a alert condition if you want to act upon this marking. What do you need look up tables in alert conditions for?
