ReST input creation: Address already in use
I’m using Graylog OVA 2.4.3 and when I try to create Input using ReST, Graylog shows the created Inputs marked as Failed: The message that I see is: Address already in use.
Here the JSon about the related input:
"title": "test_6f1c06e2-e27c-4c41-a577-bd17f37c3547",
"global": true,
"name": "Beats",
"content_pack": "5bbb21bd1838ed2ce0d6524e",
"created_at": "2018-10-08T09:22:04.207Z",
"type": "org.graylog.plugins.beats.BeatsInput",
"creator_user_id": "admin",
"attributes": {
"recv_buffer_size": 1048576,
"port": 12202,
"tls_key_file": "",
"tls_enable": false,
"tls_key_password": "",
"tcp_keepalive": false,
"tls_client_auth_cert_file": "",
"tls_client_auth": "disabled",
"override_source": "",
"bind_address": "0.0.0.0",
"tls_cert_file": ""
"static_fields": {
"ENABLE_ENRICH": "false",
"entity_name": "NONE",
"tags": "test_6f1c06e2-e27c-4c41-a577-bd17f37c3547"
"node": null,
"id": "5bbb21bc9fb73040f9349195"
The port number is 12202
Executing netstat -plnt I can see the result below
All seems correct, but Graylog give me the error message.
Looking the log file we can see the stack trace:
2018-10-08_09:22:51.44381 ERROR [InputLauncher] The [org.graylog.plugins.beats.BeatsInput] input with ID <5bbb21bc9fb73040f9349195> misfired. Reason: Address already in use.
2018-10-08_09:22:51.44430 org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /0.0.0.0:12202
2018-10-08_09:22:51.44485 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:158) ~[graylog.jar:?]
2018-10-08_09:22:51.44569 at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
2018-10-08_09:22:51.44616 at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2018-10-08_09:22:51.44721 at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_161]
2018-10-08_09:22:51.44763 at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_161]
2018-10-08_09:22:51.44805 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_161]
2018-10-08_09:22:51.44877 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_161]
2018-10-08_09:22:51.44965 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_161]
2018-10-08_09:22:51.45498 Caused by: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /0.0.0.0:12202
2018-10-08_09:22:51.45539 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:155) ~[graylog.jar:?]
2018-10-08_09:22:51.45600 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
2018-10-08_09:22:51.45675 … 7 more
2018-10-08_09:22:51.45721 Caused by: org.jboss.netty.channel.ChannelException: Failed to bind to: /0.0.0.0:12202
2018-10-08_09:22:51.45793 at org.jboss.netty.bootstrap.ServerBootstrap.bind(ServerBootstrap.java:272) ~[graylog.jar:?]
2018-10-08_09:22:51.46060 at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:141) ~[graylog.jar:?]
2018-10-08_09:22:51.46179 at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
2018-10-08_09:22:51.46210 … 7 more
2018-10-08_09:22:51.46263 Caused by: java.net.BindException: Address already in use
2018-10-08_09:22:51.46438 at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_161]
2018-10-08_09:22:51.46507 at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_161]
2018-10-08_09:22:51.46688 at sun.nio.ch.Net.bind(Net.java:425) ~[?:1.8.0_161]
2018-10-08_09:22:51.46744 at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) ~[?:1.8.0_161]
2018-10-08_09:22:51.46870 at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74) ~[?:1.8.0_161]
2018-10-08_09:22:51.47187 at org.jboss.netty.channel.socket.nio.NioServerBoss$RegisterTask.run(NioServerBoss.java:193) ~[graylog.jar:?]
2018-10-08_09:22:51.47258 at org.jboss.netty.channel.socket.nio.AbstractNioSelector.processTaskQueue(AbstractNioSelector.java:391) ~[graylog.jar:?]
2018-10-08_09:22:51.47336 at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:315) ~[graylog.jar:?]
2018-10-08_09:22:51.47365 at org.jboss.netty.channel.socket.nio.NioServerBoss.run(NioServerBoss.java:42) ~[graylog.jar:?]
2018-10-08_09:22:51.47417 at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) ~[graylog.jar:?]
2018-10-08_09:22:51.47495 at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) ~[graylog.jar:?]
2018-10-08_09:22:51.47566 … 3 more
2018-10-08_09:22:51.47672 INFO [InputStateListener] Input [Beats/5bbb21bc9fb73040f9349195] is now FAILED
If I restart Graylog the Input become valid, without changes!!
Is there something that I can do to fix this problem?
Why at the first time, Graylog say me that the input is not valid but after restarting the server, the input become good?
Gianluca
Have you tried if that is happening with the latest stable release too?
(2.4.6 at time of writing)
Hi @jan
currently I cannot upgrade my Graylog env to the last version (2.4.6).
So I can not give you an answer
Any suggestions to understand what happened?
Hi @jan
I update the env to the latest version (v 2.4.6) and I have the same problem.
Do you have any suggestions?
