Graylog 3.0 Syslog UDP input fails to start even though address is not in use
I have been trying to start a basic SYSLOG UDP input. But this FAILS to start because “address is already in use”.
First at port = 514, then I read in forum that only root can use this port or I must use firewall redirecting. For quick demo, I try change the port to a non-privileged range.
Secondly, I then try port = 8514. This also fails. Then I get frustrated and change to port 8515 and I get the same thing.
I also tried port 1514. Same thing. It is almost as if every port it anticipates I will try, becomes “address already in use”. IP address used = 0.0.0.0:8514.
Iptables off. Selinux is set to permissive. What else could I be doing wrong?
what does the Graylog server.log tell you?
2019-03-20T15:30:12.533+02:00 WARN [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=SyslogUDP Input, type=org.graylog2.inputs.syslog.udp.Sys
logUDPInput, nodeId=204dcce9-4c1d-4f1e-8ca6-6e32be4b2261} (channel [id: 0x7fd72390, L:/0:0:0:0:0:0:0:0%0:8514]) should be 262144 but is 262142.
2019-03-20T15:30:12.536+02:00 ERROR [InputLauncher] The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input with ID <5c9228643c55fa0afda766c4> misfired. Reason: bind(
…) failed: Address already in use.
org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: io.netty.channel.unix.Errors$NativeIoException: bind(…) failed: Address alrea
dy in use
at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:158) ~[graylog.jar:?]
at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_111]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_111]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_111]
Caused by: org.graylog2.plugin.inputs.MisfireException: io.netty.channel.unix.Errors$NativeIoException: bind(…) failed: Address already in use
at org.graylog2.inputs.transports.UdpTransport.launch(UdpTransport.java:135) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
… 7 more
Caused by: io.netty.channel.unix.Errors$NativeIoException: bind(…) failed: Address already in use
at io.netty.channel.unix.Errors.newIOException(Errors.java:122) ~[graylog.jar:?]
at io.netty.channel.unix.Socket.bind(Socket.java:287) ~[graylog.jar:?]
at io.netty.channel.epoll.AbstractEpollChannel.doBind(AbstractEpollChannel.java:684) ~[graylog.jar:?]
at io.netty.channel.epoll.EpollDatagramChannel.doBind(EpollDatagramChannel.java:256) ~[graylog.jar:?]
at io.netty.channel.AbstractChannel$AbstractUnsafe.bind(AbstractChannel.java:562) ~[graylog.jar:?]
at io.netty.channel.DefaultChannelPipeline$HeadContext.bind(DefaultChannelPipeline.java:1332) ~[graylog.jar:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeBind(AbstractChannelHandlerContext.java:501) ~[graylog.jar:?]
at io.netty.channel.AbstractChannelHandlerContext.bind(AbstractChannelHandlerContext.java:486) ~[graylog.jar:?]
at io.netty.channel.ChannelOutboundHandlerAdapter.bind(ChannelOutboundHandlerAdapter.java:35) ~[graylog.jar:?]
at io.netty.channel.ChannelDuplexHandler.bind(ChannelDuplexHandler.java:38) ~[graylog.jar:?]
at io.netty.channel.DefaultChannelPipeline.bind(DefaultChannelPipeline.java:984) ~[graylog.jar:?]
at io.netty.channel.AbstractChannel.bind(AbstractChannel.java:258) ~[graylog.jar:?]
at io.netty.bootstrap.AbstractBootstrap$2.run(AbstractBootstrap.java:366) ~[graylog.jar:?]
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163) ~[graylog.jar:?]
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:404) ~[graylog.jar:?]
at io.netty.channel.epoll.EpollEventLoop.run(EpollEventLoop.java:333) ~[graylog.jar:?]
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:905) ~[graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) ~[graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) ~[?:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) ~[?:1.8.0_111]
I created a syslog TCP input and it worked. For my PoC, I think this is fine. I will retry UDP input for syslog at another time.
New problem came up when testing reporting in Graylog 3.0.x
