Fail to create second syslog udp input
I already use 1 udp syslog input on port 12222
When I try to add another one on port 22222 it’s fail in 2 servers (I have 6 for redundancy and functionality frontend/backend) that in use for storage/ES with error “Address already in use.”
But I not used this address at all !
When I change input to syslog TCP it’s work all right
From log
2019-05-13T10:34:40.753+03:00 ERROR [InputLauncher] The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input with ID <5cd91ccbf6b7600490b3e83a> misfired. Reason: Address already in use.
org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /0.0.0.0:22222
at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:158) ~[graylog.jar:?]
at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_131]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
Caused by: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /0.0.0.0:22222
at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:155) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
… 7 more
Caused by: org.jboss.netty.channel.ChannelException: Failed to bind to: /0.0.0.0:22222
at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:204) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:136) ~[graylog.jar:?]
… 7 more
Caused by: java.net.BindException: Address already in use
at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_131]
at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_131]
at sun.nio.ch.DatagramChannelImpl.bind(DatagramChannelImpl.java:691) ~[?:1.8.0_131]
at sun.nio.ch.DatagramSocketAdaptor.bind(DatagramSocketAdaptor.java:91) ~[?:1.8.0_131]
at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.bind(NioDatagramPipelineSink.java:129) ~[graylog.jar:?]
at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.eventSunk(NioDatagramPipelineSink.java:77) ~[graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779) ~[graylog.jar:?]
at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) ~[graylog.jar:?]
at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) ~[graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) ~[graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) ~[graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582) ~[graylog.jar:?]
at org.jboss.netty.channel.Channels.bind(Channels.java:561) ~[graylog.jar:?]
at org.jboss.netty.channel.AbstractChannel.bind(AbstractChannel.java:197) ~[graylog.jar:?]
at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:198) ~[graylog.jar:?]
… 7 more
2019-05-13T10:34:40.755+03:00 INFO [InputStateListener] Input [Syslog UDP/5cd91ccbf6b7600490b3e83a] is now FAILED
you should check in the servers where it fails if some other kind of software uses that port …
reboot server and now it is ok
