Read permission for individual source
Hi
I was wondering if we can make a individual input’s message read-only for users, for eg. I have 5 input sources
  • Nginx
  • Rails
  • Java etc. etc.
I want to give access for Rails source to a set of users at same time I don’t want them to see logs from other sources.
I use used Role API and created “source:read” role but it allows user to read all the sources.
Any idea how we can achieve it for specific source.
TIA
That is what streams are made for.
http://docs.graylog.org/en/2.4/pages/streams.html
Create a Stream for each usergroup and route the data that should be visible to them into this streams.
Thanks Jan… it worked :slight_smile:
