Restrict read to access streams
Hi there,
How do I restrict reading to access streams?
Is that possible?
I don’t want to grant access to all streams. Because a few streams are important.
Example for something that does not work:
  "name": "Reader",
  "description": "Grants basic permissions for every Graylog user (built-in)",
  "permissions": [
    "streams:read"
      read: "id_1, id_2",
      read: "logs_*"
  "read_only": true
What version of Graylog are you on?
Are you looking to do this exclusively via the API or would doing it through the UI work as well?
Hi
I using version Graylog 4.1.3+9d79c05
Can you tell me both ways I would be very grateful
Thank you so much.
hey @duydo1
I see you want to learn about permissions on Streams? If this is correct perhaps these links would enlighten you on how to go about that
hope that helps
