Hey everyone,
I’ve been trying to put to work a pipeline that integrates my fortigate logs (that come to graylog via syslog) with Greynoise, but unfortunetly it’s not working. It does not make any enrichment to my data.
So the following image shows the rule that I am using.
The lookup table is working properly, as i can do lookup tests and it works.
The logs that I am trying to enrich have the dstip field like we can see in the following image:
With all this configured, this is the pipeline config:
As we can see the logs are not being enrich, because the rule is not matching any logs. Is there anything that I’m missing in here?
Thank you in advance for any help you can provide!
