Pipeline/Data Enrichment Issue
Trying to enrich the logs associated with OPNSense filterlogs. I currently have netflow logs being enriched with GeoIP and OTX/Whois data with now issue. I basically modified the same rules to adjust to the field naming differences for source and destination IP between the filterlog and netflow, but the filterlog is not getting the updated enriched fields.
  • OS Information:
Graylog Graylog 5.1.0+14ba491
OS: Ubuntu 22.04.2 LTS x86_64
Kernel: 5.15.0-72-generic
Shell: bash 5.1.16
CPU: AMD Ryzen 9 6900HX with Radeon Graphics (16) @ 3.300GHz
Memory: 4978MiB / 28839MiB
OPNsense 23.1.7_3-amd64
OS: FreeBSD 13.1-RELEASE-p7
CPU: Intel(R) Core™ i7-1165G7 @ 2.80GHz (4 cores, 8 threads)
Memory: 9970/32463 MB
  • Package Version:
    Open Threat Exchange - Threat Intel Plugin
    Whois Threat Intel Plugin
    OPNSense Content Pack
    ###Logs Anonymized###
    Sample filterlog missing enrichment
  "reason": "match",
  "src-ip": "89.248.165.118",
  "dst-ip": "x.x.x.109",
  "gl2_remote_ip": "192.168.2.1",
  "src-port": "52302",
  "gl2_remote_port": 9269,
  "dst-port": "2221",
  "source": "x.x.x",
  "gl2_source_input": "6465140d3f6c1762ab247d54",
  "interface": "igc0",
  "protocol-name": "tcp",
  "f2": "1024",
  "ip-flags": "none",
  "rule-number": "112",
  "tracker": "07c7d99fd89b2a05fb88b21a9a4348ca",
  "action": "block",
  "tos": "0x0",
  "gl2_source_node": "143077a1-1f14-4cc9-8794-4b1a211f4aad",
  "id": "39338",
  "timestamp": "2023-05-21T20:46:06.000Z",
  "direction": "in",
  "datalength": "0",
  "gl2_accounted_message_size": 799,
  "offset": "0",
  "level": 6,
  "streams": [
    "646a6fa1c811d25121010111",
    "646515243f6c1762ab247fa7"
  "length": "40",
  "gl2_message_id": "01H100ZVNG007D0VW6KA8KTXP8",
  "ip-version": "4",
  "message": "x.x.x filterlog[15109]: 112,,,07c7d99fd89b2a05fb88b21a9a4348ca,igc0,match,block,in,4,0x0,,239,39338,0,none,6,tcp,40,89.248.165.118,x.x.x.109,52302,2221,0,S,2540593770,,1024,,",
  "ttl": "239",
  "tcp-flags": "S",
  "sequence": "2540593770",
  "facility_num": 16,
  "protocol-id": "6",
  "filterlog_ipv4_tcp": "112,,,07c7d99fd89b2a05fb88b21a9a4348ca,igc0,match,block,in,4,0x0,,239,39338,0,none,6,tcp,40,89.248.165.118,x.x.x.109,52302,2221,0,S,2540593770,,1024,,",
  "_id": "8225eae0-f818-11ed-9376-0242cc279576",
  "facility": "local0"
Sample filterlog source IP Pipeline GeoIP and Threat Intel Rule:
rule "filterlog src-ip geoip lookup"
 has_field("src-ip") && ! in_private_net(to_string($message.src_ip))
  let geo = lookup("geoip-lookup", to_string($message.src_ip));
  set_field("src_ip_geolocation", geo["coordinates"]);
  set_field("src_ip_geo_country_code", geo["country"].iso_code);
  set_field("src_ip_geo_country_name", geo["country"].names.en);
  set_field("src_ip_geo_city_name", geo["city"].names.en);
rule "filterlog src-ip threat intel"
let dst_addr_intel = threat_intel_lookup_ip(to_string($message.src_ip), "src_addr");
set_fields(dst_addr_intel);
let dns_question_intel = threat_intel_lookup_domain(to_string($message.dns_question), "dns_question");
set_fields(dns_question_intel);
let whois_intel = whois_lookup_ip(to_string($message.src_addr), "src_addr");
set_fields(whois_intel);
Sample netflow with enrichment
  "nf_src_tos": 0,
  "nf_version": 9,
  "dst_ip_geo_country_name": "United States",
  "gl2_remote_port": 14115,
  "nf_in_bytes": 79,
  "nf_pkts": 1,
  "source": "192.168.2.1",
  "gl2_source_input": "64663b35b4873d45195d7e41",
  "nf_tcp_flags": 0,
  "nf_bytes": 79,
  "nf_src_as": 0,
  "nf_out_pkts": 0,
  "nf_dst_address": "8.8.4.4",
  "src_ip_geolocation": "33.1177,-96.6791",
  "nf_ipv4_src_addr": "x.x.x.109",
  "nf_src": "x.x.x.109:34174",
  "dst_addr_threat_indicated": false,
  "gl2_accounted_message_size": 1272,
  "nf_flow_packet_id": 21709,
  "dst_ip_geo_country_code": "US",
  "nf_out_bytes": 0,
  "streams": [
    "64664465b4873d45195d917b"
  "dst_ip_geolocation": "34.0544,-118.2441",
  "gl2_message_id": "01H1014J20000J5J5H3G076NQJ",
  "nf_ipv4_dst_addr": "8.8.4.4",
  "nf_proto_name": "UDP",
  "nf_src_addressr_whois_country_code": "US",
  "nf_l4_dst_port": 53,
  "src_ip_geo_city_name": "city",
  "_id": "ddcaea87-f818-11ed-9376-0242cc279576",
  "nf_start": "2023-05-21T20:48:22.000Z",
  "nf_dst": "8.8.4.4:53",
  "nf_last_switched": 1100487000,
  "nf_stop": "2023-05-21T20:48:22.000Z",
  "nf_protocol": 17,
  "nf_l4_src_port": 34174,
  "nf_dst_port": 53,
  "nf_ipv4_next_hop": "x.x.x.1",
  "nf_proto": 17,
  "dst_ip_geo_city_name": "Los Angeles",
  "nf_src_port": 34174,
  "nf_src_address_threat_indicated": false,
  "timestamp": "2023-05-21T20:48:40.000Z",
  "src_ip_geo_country_name": "United States",
  "nf_dst_mask": 0,
  "nf_input_snmp": 11,
  "message": "NetFlowV9 [x.x.x.109]:34174 <> [8.8.4.4]:53 proto:17 pkts:1 bytes:79",
  "nf_dst_as": 0,
  "nf_src_address": "x.x.x.109",
  "nf_src_addressr_whois_organization": "AT&T Corp. (AC-3280)",
  "nf_src_mask": 32,
  "dns_question_threat_indicated": false,
  "nf_in_pkts": 1,
  "nf_first_switched": 1100487000,
  "nf_snmp_input": 11,
  "src_ip_geo_country_code": "US",
  "nf_snmp_output": 1,
  "nf_output_snmp": 1,
  "nf_next_hop": "x.x.x.1"
Sample netflow source IP Pipeline GeoIP and Threat Intel Rule:
rule "src-ip geoip lookup"
 has_field("nf_src_address") && ! in_private_net(to_string($message.src_ip))
  let geo = lookup("geoip-lookup", to_string($message.nf_src_address));
rule "src-ip threat intel"
let src_addr_intel = threat_intel_lookup_ip(to_string($message.nf_src_address), "nf_src_address");
set_fields(src_addr_intel);
let whois_intel = whois_lookup_ip(to_string($message.nf_src_address), "nf_src_addressr");
As stated above, the netflow enrichment works and just duplicated and modified the rules to account for the source and destination IPs for the OPNSense filterlog. I am basically at a loss as to why the logs within Graylog are not updating.
Needing a second pair (or more) eyes to see what I am overlooking…or other recommendations…
Your code looks good to me. I’ve got a couple of other thoughts:
I recently had a problem with OTX and it turns out I was hitting their limit for free lookups. Could that be the situation here? Even the paid account has limits, so not sure if that is a consideration.
Is there a reason you could not normalize your field names and use the same pipeline rule in multiple places, rather than having a separate rule? I know that is not really an answer to your problem, but perhaps it could be helpful in troubleshooting whether the issue is in the code or somewhere else.
Good luck, let us know what the eventual solution is.
@faen I tried that and was not working. It was probably the way I had it setup, but I was able to get the threat intel enrichment within the filterlogs by creating a separate pipeline. Now trying to determine why the geoip is not enriching in the filterlog even though I see processing within the pipeline…
Hey @secdoc
Just curious, what input are you using? By chance is it Netflow input?
@gsmith This is my input for netflow. I am sending the netflow from my OPNSense FW.
Can I ask how you have your geoip-lookup table configured? You look to be getting country, city and location from the one lookup.
@wdarcey Here is the Lookup Table as I have it configured. I am using the maxmind database.
I then have a pipeline setup to enrich the data. Here is a sample rule:
If you are using the maxmind database, the the city database has a mojority of the city information across the countries…
@secdoc Many thanks.
I did not realise all were available from the same db. Consequently I wondered if accessing non-existent fields might have caused your issue.
@wdarcey No problem…I used the following resource GeoIP from the Graylog site to setup the DB and associated config…
