Problems running graylog on google cloud VPS
I’m using the following docker-compose file:
version: '2'
services:
  mongo-db:
    image: "mongo:3"
  elasticsearch-db:
    image: "elasticsearch:2"
    command: "elasticsearch -Des.cluster.name='graylog'"
  graylog:
    image: graylog2/server:2.1.1-1
    environment:
      GRAYLOG_PASSWORD_SECRET: <redacted>
      GRAYLOG_ROOT_PASSWORD_SHA2: <redacted>
      GRAYLOG_WEB_ENDPOINT_URI: http://127.0.0.1:9000/api
    links:
      - mongo-db:mongo
      - elasticsearch-db:elasticsearch
    ports:
      - "9000:9000"
      - "12201:12201/udp"
And when running docker-compose locally I start it without a problem. I can connect to it, push logs, etc. However, upon activating it on GCE I have issues.
First I use docker-machine:
eval $(docker-machine env m)
docker-compose -f <path> -p <name> up -d
Firewall allows TCP 9000 to pass and when I reach server on google, on :9000 I get Server currently unavailable
With more details I have:
Error message
Bad request
Original Request
GET http://127.0.0.1:9000/api/system/sessions
Status code
undefined
Full error message
Error: Request has been terminated
Possible causes: the network is offline, Origin is not allowed by Access-Control-Allow-Origin, the page is being unloaded, etc.
Not sure what’s the issue or how to debug it.
Here are some last few lines from graylog docker log:
2017-08-01 17:25:00,868 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2017-08-01 17:25:00,885 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical, running forever.
2017-08-01 17:25:00,900 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical, running forever.
2017-08-01 17:25:00,905 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2017-08-01 17:25:00,933 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
2017-08-01 17:25:00,942 INFO : org.graylog2.periodical.UserPermissionMigrationPeriodical - Marking user permission migration as done.
2017-08-01 17:25:00,955 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2017-08-01 17:25:00,978 INFO : org.graylog2.periodical.ConfigurationManagementPeriodical - Migrated "elasticsearch_max_docs_per_index" setting: MessageCountRotationStrategyConfig{type=org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategyConfig, maxDocsPerIndex=20000000}
2017-08-01 17:25:00,981 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.usagestatistics.UsageStatsNodePeriodical] periodical in [300s], polling every [21600s].
2017-08-01 17:25:00,989 INFO : org.graylog2.periodical.ConfigurationManagementPeriodical - Migrated "elasticsearch_max_size_per_index" setting: SizeBasedRotationStrategyConfig{type=org.graylog2.indexer.rotation.strategies.SizeBasedRotationStrategyConfig, maxSize=1073741824}
2017-08-01 17:25:00,994 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.usagestatistics.UsageStatsClusterPeriodical] periodical in [300s], polling every [21600s].
2017-08-01 17:25:00,999 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2017-08-01 17:25:01,018 INFO : org.graylog2.periodical.ConfigurationManagementPeriodical - Migrated "elasticsearch_max_time_per_index" setting: TimeBasedRotationStrategyConfig{type=org.graylog2.indexer.rotation.strategies.TimeBasedRotationStrategyConfig, rotationPeriod=P1D}
2017-08-01 17:25:01,028 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:4, serverValue:4}] to mongo:27017
2017-08-01 17:25:01,107 INFO : org.graylog2.periodical.ConfigurationManagementPeriodical - Migrated "elasticsearch_max_number_of_indices" setting: ClosingRetentionStrategyConfig{type=org.graylog2.indexer.retention.strategies.ClosingRetentionStrategyConfig, maxNumberOfIndices=20}
2017-08-01 17:25:01,142 INFO : org.graylog2.periodical.ConfigurationManagementPeriodical - Migrated "elasticsearch_max_number_of_indices" setting: DeletionRetentionStrategyConfig{type=org.graylog2.indexer.retention.strategies.DeletionRetentionStrategyConfig, maxNumberOfIndices=20}
2017-08-01 17:25:01,192 INFO : org.graylog2.periodical.ConfigurationManagementPeriodical - Migrated "rotation_strategy" and "retention_strategy" setting: IndexManagementConfig{rotationStrategy=org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategy, retentionStrategy=org.graylog2.indexer.retention.strategies.DeletionRetentionStrategy}
2017-08-01 17:25:01,233 INFO : org.graylog2.periodical.ConfigurationManagementPeriodical - Creating searches cluster config: SearchesClusterConfig{queryTimeRangeLimit=PT0S, relativeTimerangeOptions={PT5M=Search in the last 5 minutes, PT15M=Search in the last 15 minutes, PT30M=Search in the last 30 minutes, PT1H=Search in the last 1 hour, PT2H=Search in the last 2 hours, PT8H=Search in the last 8 hours, P1D=Search in the last 1 day, P2D=Search in the last 2 days, P5D=Search in the last 5 days, P7D=Search in the last 7 days, P14D=Search in the last 14 days, P30D=Search in the last 30 days, PT0S=Search in all messages}, surroundingTimerangeOptions={PT1S=1 second, PT5S=5 seconds, PT10S=10 seconds, PT30S=30 seconds, PT1M=1 minute, PT5M=5 minutes}, surroundingFilterFields=[source, gl2_source_input, file, source_file]}
2017-08-01 17:25:01,386 INFO : org.elasticsearch.transport - [graylog-2ef3a6bb-6c01-43e4-b377-9a621f92f406] publish_address {172.18.0.4:9350}, bound_addresses {0.0.0.0:9350}
2017-08-01 17:25:01,416 INFO : org.elasticsearch.discovery - [graylog-2ef3a6bb-6c01-43e4-b377-9a621f92f406] graylog/bIyQb6MuT7Sth72mJgfcSw
2017-08-01 17:25:02,471 INFO : org.graylog2.shared.initializers.JerseyService - Enabling CORS for HTTP endpoint
2017-08-01 17:25:04,440 WARN : org.elasticsearch.discovery - [graylog-2ef3a6bb-6c01-43e4-b377-9a621f92f406] waited for 3s and no initial state was set by the discovery
2017-08-01 17:25:04,442 INFO : org.elasticsearch.node - [graylog-2ef3a6bb-6c01-43e4-b377-9a621f92f406] started
2017-08-01 17:25:04,906 INFO : org.elasticsearch.cluster.service - [graylog-2ef3a6bb-6c01-43e4-b377-9a621f92f406] detected_master {Power Man}{uFLZNAyQTSem8Nfyrgb3hA}{172.18.0.3}{172.18.0.3:9300}, added {{Power Man}{uFLZNAyQTSem8Nfyrgb3hA}{172.18.0.3}{172.18.0.3:9300},}, reason: zen-disco-receive(from master [{Power Man}{uFLZNAyQTSem8Nfyrgb3hA}{172.18.0.3}{172.18.0.3:9300}])
2017-08-01 17:25:10,809 INFO : org.graylog2.indexer.Deflector - Did not find an deflector alias. Setting one up now.
2017-08-01 17:25:10,826 INFO : org.graylog2.indexer.Deflector - There is no index target to point to. Creating one now.
2017-08-01 17:25:10,860 INFO : org.graylog2.indexer.Deflector - Cycling deflector to next index now.
2017-08-01 17:25:10,869 INFO : org.graylog2.indexer.Deflector - Cycling from <none> to <graylog_0>
2017-08-01 17:25:10,870 INFO : org.graylog2.indexer.Deflector - Creating index target <graylog_0>...
2017-08-01 17:25:12,266 INFO : org.graylog2.indexer.indices.Indices - Created Graylog index template "graylog-internal" in Elasticsearch.
2017-08-01 17:25:14,078 INFO : org.graylog2.indexer.Deflector - Waiting for index allocation of <graylog_0>
2017-08-01 17:25:14,387 INFO : org.graylog2.indexer.Deflector - Done!
2017-08-01 17:25:14,387 INFO : org.graylog2.indexer.Deflector - Pointing deflector to new target index....
2017-08-01 17:25:14,462 INFO : org.graylog2.indexer.Deflector - Done!
2017-08-01 17:25:24,438 INFO : org.glassfish.grizzly.http.server.NetworkListener - Started listener bound to [0.0.0.0:9000]
2017-08-01 17:25:24,446 INFO : org.glassfish.grizzly.http.server.HttpServer - [HttpServer] Started.
2017-08-01 17:25:24,453 INFO : org.graylog2.shared.initializers.JerseyService - Started REST API at <http://0.0.0.0:9000/api/>
2017-08-01 17:25:24,454 INFO : org.graylog2.shared.initializers.JerseyService - Started Web Interface at <http://0.0.0.0:9000/>
2017-08-01 17:25:24,458 INFO : org.graylog2.bootstrap.ServerBootstrap - Services started, startup times in ms: {OutputSetupService [RUNNING]=52, BufferSynchronizerService [RUNNING]=57, KafkaJournal [RUNNING]=62, InputSetupService [RUNNING]=120, JournalReader [RUNNING]=244, PeriodicalsService [RUNNING]=317, IndexerSetupService [RUNNING]=4274, JerseyService [RUNNING]=23762}
2017-08-01 17:25:24,461 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server up and running.
2017-08-01 17:25:24,461 INFO : org.graylog2.shared.initializers.ServiceManagerListener - Services are healthy
2017-08-01 17:25:24,463 INFO : org.graylog2.shared.initializers.InputSetupService - Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
You have to set rest_listen_uri and rest_transport_uri accordingly.
Ok; I’ve changes my docker-compose file setting from:
GRAYLOG_WEB_ENDPOINT_URI: http://127.0.0.1:9000/api to
GRAYLOG_WEB_ENDPOINT_URI: http://<server public IP>:9000/api
and update graylog2/server to newer version 2.3.0
Now I’ve managed to login and add data source. I see data going into the datasource, however when I wish to see messages following error pops out:
Could not load field information Loading field information failed with status: cannot GET http://<server public IP>:9000/api/system/fields (500)
In the logs of interest I have:
graylog_1           | 2017-08-02 12:05:19,761 WARN : org.graylog2.migrations.V20161130141500_DefaultStreamRecalcIndexRanges - Interrupted or timed out waiting for Elasticsearch cluster, checking again.
graylog_1           | 2017-08-02 12:05:47,986 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn't read cluster health for indices [graylog_*] (Could not connect to http://127.0.0.1:9200)
graylog_1           | 2017-08-02 12:05:47,988 INFO : org.graylog2.periodical.IndexerClusterCheckerThread - Indexer not fully initialized yet. Skipping periodic cluster check.
graylog_1           | 2017-08-02 12:06:17,986 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn't read cluster health for indices [graylog_*] (Could not connect to http://127.0.0.1:9200)
graylog_1           | 2017-08-02 12:06:17,988 INFO : org.graylog2.periodical.IndexerClusterCheckerThread - Indexer not fully initialized yet. Skipping periodic cluster check.
graylog_1           | 2017-08-02 12:06:19,761 WARN : org.graylog2.migrations.V20161130141500_DefaultStreamRecalcIndexRanges - Interrupted or timed out waiting for Elasticsearch cluster, checking again.
and
graylog_1           | 2017-08-02 12:15:52,154 ERROR: org.graylog2.indexer.messages.Messages - Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #23).
graylog_1           | 2017-08-02 12:16:01,405 ERROR: org.graylog2.indexer.messages.Messages - Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #23).
graylog_1           | 2017-08-02 12:16:02,465 ERROR: org.graylog2.indexer.messages.Messages - Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #23).
graylog_1           | 2017-08-02 12:16:02,908 ERROR: org.graylog2.indexer.messages.Messages - Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #23).
graylog_1           | 2017-08-02 12:16:17,985 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn't read cluster health for indices [graylog_*] (Could not connect to http://127.0.0.1:9200)
graylog_1           | 2017-08-02 12:16:17,986 INFO : org.graylog2.periodical.IndexerClusterCheckerThread - Indexer not fully initialized yet. Skipping periodic cluster check.
graylog_1           | 2017-08-02 12:16:19,782 WARN : org.graylog2.migrations.V20161130141500_DefaultStreamRecalcIndexRanges - Interrupted or timed out waiting for Elasticsearch cluster, checking again.
I’m not sure what I should do next to get it working. Is this related to rest_listen_uri and I should set GRAYLOG_REST_LISTEN_URI environment variable in docker-compose .yml or do something else instead?
Also related thing,
on the server only TCP ports 8000-9000 are openned; should I open anything else?
I see it trying to connect to http://127.0.0.1:9200 ;however, that is local IP and I doubt google firewall has anything to do with it?
You have to configure elasticsearch_hosts accordingly.
Ok, how do I do that with docker-compose? I’m getting kinda lost right now with docker-compose, and correct elasticsearch_host IPs.
Does elasticsearch must be visible from web interface or from REST API server?
I could use internal GCE IP, 10.<…> here I assume? How come it worked properly when testing on localhost, but it suffers issues during deploying to GCE with elasticsearch?
Graylog must be able to communicate with the HTTP API of Elasticsearch (default port 9200/tcp).
After reading docker-compose documentation, I’ve added:
GRAYLOG_ELASTICSEARCH_HOSTS: http://elasticsearch:9200/
I think there was a race condition, since I saw elasticsearch broadcasting its IP on the network and graylog picking it up I assume? Because it should be working at all on the localhost?
What about mongo; is there also some default HOST:IP I have to setup or?
There’s the mongodb_uri configuration setting for that.
Ok, I think this solves my issue. Takeaway:
  • How does it even work in docker-compose file provided? In my understanding graylog defaults to localhost and should fail miserably to find mongodb/elasticsearch
  • I suggest adding mongodb_uri and elasticsearch_uri to official docker-compose file
The Graylog Docker image already has the correct settings:
