Graylog_deflector
fresh installation (on ubuntu docker-compose)gave me ERROR: org.graylog2.indexer.cluster.Cluster - Couldn’t read cluster health for indices [graylog_deflector]
i can’t login to graylog.
Graylog is not able to connect to Elasticsearch
i don’t now what happend i remove all images and start with docker-compose up it’s running now.
it’s running on local broswer and when i curl it it’s running on 172.18.0.4
Do you know how to call it from remote browser?
no, because you do not shared anything from your environment that might help someone.
ok. i try to login to raylog from adress 10.X.X.X but graylog on docker has adress 172.17.0.1
172.18.0.1
and docker network ls is
NETWORK ID NAME DRIVER SCOPE
7ed116ca4800 bridge bridge local
b8151d8006bc docker-compose_default bridge local
7fee232e5ac9 host host local
d07cec18884e none null local
how to login to graylog from adress 10.x.x.x.
please read the Documentation: http://docs.graylog.org/en/3.0/pages/configuration/server.conf.html#web-rest-api
