Couldn't read cluster health for indices [graylog_*] (Could not connect to http://127.0.0.1:9200)
I have been trying to solve this issue for 4 hours now and im stuck.
Just setup docker. We are running with one server running docker from where we use the version 3 docker-compose from the documentation with some added stuff.
From my findings my issue could be that is should change the address to connect to, to elastisearch:9200 or something like that. The address is not important because if it is the issue i can’t find where to put it in?
i’m running with the conf file that graylock docker documentation suggest aswell.
I could use a push in the right direction.
Also port 9000 is not open it seams, but this could because of this problem i’m not sure.
docker-compose file:
Sorry I usually solve the problems i have myself, so im not used to the quote stuff here… im trying :slightly_smiling_face:
Here is the graylog.conf
i don’t see what im doing wrong with the quotes
how do i get it to compact so its not just one long post?
nevermind! i solved it another way
