Problem with pie chart visualization
can someone help to make a pie chart like Kibana i am working on net flow logs , i need to make a Pie chart aggregates a specific field called (nf_bytes) then split pie with a field like src_address or port like src_port so that i can get which src address used the most (bytes) & of course it will take a color occupy the most of pie area than others
thanks .
