Hey all,
i have installed and configured graylog v3.3.2 and received a notification to upgrade to v3.3.3.
However i download the .deb package and trying to install it i get the below notification.
“graylog-server is already the newest version (3.3.2-1)”
I have ubuntu 20.04 LTS and ES version 6.8.10.
Is this a bug or compatibility issue?
thank you in advance
Why did you manually download .deb file… better way is to use official apt repository, so you can use simple commands to update graylog:
apt update
apt upgrade
How did you install graylog? Using official docs?
https://docs.graylog.org/en/3.2/pages/installation/os/ubuntu.html
Hey, thanks for your reply.
I followed the official documentaion, that’s why. apt-get update are included laso in the documentation as you suggested but still no luck.
https://docs.graylog.org/en/3.3/pages/installation/operating_system_packages.html#operating-package-upgrade-deb-apt
wget https://packages.graylog2.org/repo/packages/graylog-3.3-repository_latest.deb
sudo dpkg -i graylog-3.3-repository_latest.deb
sudo apt-get update
sudo apt-get install graylog-server
Check available packages in repo:
sudo apt-cache policy graylog-server
My installation shows 3.3.3-1 as a latest version
Check also installed package version:
sudo dpkg -l graylog-server
thanks.
This is what I’m getting
$ sudo apt-cache policy graylog-server
graylog-server:
Installed: 3.3.2-1
Candidate: 3.3.2-1
Version table:
*** 3.3.2-1 100
100 /var/lib/dpkg/status
$ sudo dpkg -l graylog-server
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii graylog-server 3.3.2-1 all Graylog server
Maybe you use some proxy server, that cache results, or mirror is not updated yet.
Unfortunately, in this case, I’m not using any proxy server.
Any other thoughts?
Hello, problem solved with the next update v3.3.4 following the procedure from the documentaion found here.
