Pipeline Rules Works if Streams is set to "All Messages" but not specific Stream
Pipeline Rules Works if Connection Stream is set to “All Messages” but not when a specific Stream is selected.
I have searched the boards, google, youtube… I think I am doing it right… maybe?!
Using Graylog OVA 4.0.7+c3e766c
Any guidance is appreciated.
Arn
Please send more informations, your graylog version, your stream configuration, your pipeline rule, your processing order and so on. Otherwhise it’s not possible to help you.
Simple rule from Graylog blog (I tihnk it was from a graylog blog)
rule “enrichment_rfc1918_dst_ip”
has_field(“source”)
AND
// check if rfc1918, only one of these must be true
cidr_match(“10.0.0.0/8”, to_ip($message.source))
OR
cidr_match(“172.16.0.0/12”, to_ip($message.source))
OR
cidr_match(“192.168.0.0/16”, to_ip($message.source))
OR
cidr_match(“127.0.0.0/8”, to_ip($message.source))
set_field(“dst_ip_is_internal”, true);
Simple syslog from Sonicwall
Syslog Index created
Stream is associated with the Syslog index created
When the pipeline is connected to “All Streams” it works
When the pipeline is connected to the Syslog Stream it does not work
Thank you,
Arn
