v. 2.2.0
I am unable to apply Pipeline Rules to Streams other than the default “All Messages” stream. When the Pipeline connection is set to any other Stream the rules are not applied. Messages appear to be going through the Pipeline either way.
Here is the Rule:
rule "ssh_session_opened extraction"
has_field("type") && to_string($message.type) == "syslog"
let message_field = to_string($message.message);
let action = grok(pattern: "%{SYSLOG_SSHD_SESSISON_OPENED}", value: message_field, only_named_captures: true);
set_fields(action);
%{SYSLOG_SSHD_SESSISON_OPENED} is defined in Graylog as:
%{SYSLOGTIMESTAMP:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA:syslog_program}(?:\[%{POSINT:syslog_pid}\])?: %{WORD:pam_type}\(%{DATA:pam_message}\): session opened for user %{USER:pam_username} by \(uid=%{USERNAME:pam_uid:int}\)
