Hello
Im trying to create a new field within IIS logs for a username / ip combination using pipelines.
So far I can get a new field to appear in the logs, but it contains the literal field name not the actual field values I was expecting.
Ive read all the the posts in this forum that I could find that looked similar, but have not found a solution yet.
Here are the details:
IIS logs are sent from a windows server via nxlog using the w3c extension
<Extension w3c>
Module xm_csv
Fields $date, $time, $s-ip, $cs-method, $cs-uri-stem, $cs-uri-query, $s-port, $cs-username, $c-ip, $csUser-Agent, $cs-Referer, $sc-status, $sc-substatus, $sc-win32-status, $time-taken $X-Forwarded-For
FieldTypes string, string, string, string, string, string, integer, string, string, string, string, integer, integer, integer, integer, string
Delimiter ' '
EscapeChar '"'
QuoteChar '"'
EscapeControl FALSE
UndefValue -
</Extension>
With
OutputType GELF
In graylog, the processing order is like this:
1|AWS Instance Name Lookup |active
2|GeoIP Resolver |active
3|Message Filter Chain |active
4|Pipeline Processor |active
The pipeline rule looks like this:
rule "user and ip"
has_field("c-ip") AND has_field("cs-username")
let userandip = concat(to_string("$message.cs-username"), (to_string("$message.c-ip")));
set_field("mynewfieldforuserandip", userandip);
The resulting log now has the field ‘mynewfieldforuserandip’, but its value is:
$message.cs-username$message.c-ip
both fields ‘c-ip’ and ‘cs-username’ exist in the log message.
Ive tried different variations in this rule, including just setting one field to another rather than concat, but same result.
Does anyone know how this should be done?
