I am trying to concatenate the DstName and Path fields into the URL field. Below is the pipeline config I currently have and an example of the two fields I am trying to concatenate:
rule "URL"
has_field("DstName") && has_field("Path")
let URL = concat(to_string($message.DstName), to_string($message.Path));
set_field("URL", URL);
DstName:go.microsoft.com
Path:/fwlink/?LinkID_2233=2233yxa
My expected outcome would be as follows:
URL:go.microsoft.com/fwlink/?LinkID_2233=2233yxa
jan
(Jan Doberstein)
March 26, 2018, 2:11pm
2
I have looked at the documentation and the pipeline rule I created should have worked, I am not sure why it’s not?
Any ideas?
Cheers,
George
jan
(Jan Doberstein)
March 27, 2018, 6:14am
4
without knowing your messages?
Sorry my is currently out of order …
Maybe your when condition did not work, or your Fieldnames are different. Try to use the debug function to find the reason.
regards
Jan
Haha, sorry for my lack on information. Below is an example of a log that I am trying to perform the concat on.
AppCategoryID
13
AppCategoryName
Web services
AppID
8
AppName
Google Chrome
DstIP
123.123.123.123
DstName
https://community.graylog.org
DstPort
80
GeoDst
USA
GeoSrc
USA
HTTPMethod
GET
Hour
9
Message
HTTP request
MsgID
1AFF-0024
Path
/t/concatenate-two-fields/4741/4
Protocol
tcp
ProxyAct
HTTP Proxy.1
ReceivedBytes
918
Reputation
1
RuleAction
Allow
RuleName
Proxy Access
SentBytes
697
SrcIP
321.321.321.321
SrcPort
63210
TargetUserName
MYNAME@MYCOMPANY.COM
TimeElapsed
0.189354 sec(s)
TimeStamp
2018-03-27T08:56:46
Type
Proxy Log
Zone
1-Untrusted 3-Out
I hope you can get a better idea of what I’m trying to do and the fields I am working with. I just want to create the URL from those two fields.
Cheers,
G
jan
(Jan Doberstein)
March 27, 2018, 10:12am
6
are those fields available in Graylog as seperate fields already? If yes, that should work.
Here’s a screenshot of part of a log file. As you can see both fields are there, I don’t understand why it’s not working.
Message filtering is done before pipelines so the fields are present when being processed by the pipleline.
jan
(Jan Doberstein)
March 27, 2018, 11:57am
8
you should now debug that step-by-step.
Write a field “debug” if the condition is matching - then you can see if that part of the rule is working. If that is working, write as debug message the content of both fields to the logfile
( http://docs.graylog.org/en/2.4/pages/pipelines/functions.html?debug#debug )
This is the best way to check what is working and what not.
