Pipeline rules - Concatenate two Grok extractor field
I’m trying to combine two grok fields to a single field.
Example: Currently my grok extractors has field “src_ip” and “dst_ip”. Now I want to use the pipeline rules to combine both the field src_ip and dst_ip to a single field with name “src_dst_ip”.
How do I achieve this with pipeline rules? , Please post me the example.rule creation.Thanks
I’m trying with the below rule in the pipeline and it does not show in a search field.
rule "Combine src and dst field"
    has_field("$message.src_ip") && has_field("$message.dst_ip")
let src_dst_ip = concat( "$message.src_ip" , "$message.dst_ip" ) ;
Expectation
src_ip = 192.168.1.1
dst_ip = 10.1.1.1
src_dst_ip = 192.168.1.1 , 10.1.1.1
You only define a variable named src_dst_ip with the literal content $message.src_ip$message.dst_ip in your rule but you don’t assign that anywhere.
You need to use the set_field() function to assign a value to a message field.
Hi Jochen,
Thanks for the reply. I’m little confused about the set_field() function and I don’t know how to assign a value to it.
This is my sample raw message that is reporting to gray log
“2017-06-12 05:40:50.837390 IP 192.168.96.1.5366 > 192.168.96.141.12900: Flags [S], seq 1252815841, win 8192, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0”
And my Grok Extractor looks like this
grok_pattern: %{TIMESTAMP_ISO8601:timestamp} IP %{IP:src_ip}.%{INT:src_port} > %{IP:dst_ip}.%{INT:dst_port}(?[^$]+)
Output of Grok pattern for the field src_ip and dst_ip
dst_ip
192.168.96.141
src_ip
192.168.96.1
In this, if you see I have two field src_ip and dst_ip. Now I wanted to use pipeline rule to combine this two field value.
Please let me know how do I accomplish this with pipeline rules
"set_field syntax
set_field(field: string, value: any, [message: Message])"
See here for some examples for the set_field() function:
Hey @sathishdsgithub,
this would be your code:
    let src_dst_ip = concat( "$message.src_ip", " , ", "$message.dst_ip" ) ;
    set_field(field:"src_dst_ip", value: src_dst_ip)";
Explanation:
I added " , " because this will add the comma you stated above (src_dst_ip = 192.168.1.1 , 10.1.1.1)
This will add a field to the message named src_dst_ip with the value in the variable src_dst_ip.
Greetings - Phil
Hi Phil,
Thanks a lot for providing me the information.
I have applied the pipeline rules as shown below, but this is not showing in my search field. Do I need to make any additional configurations? I have followed the exact steps mentioned in the below link
http://docs.graylog.org/en/2.2/pages/pipelines/usage.html
rule “Combine src and dst field"
has_field(”$message.src_ip") && has_field("$message.dst_ip")
let src_dst_ip = concat( “$message.src_ip”, “$message.dst_ip” ) ;
set_field(field:“src_dst_ip”, value: src_dst_ip);
Did you attach the rule to a pipeline, that is attached to a stream that the messages in question are running through? If yes, can you look inside the Graylog Interface under Indexer errors and the Graylog Logfile for errors? And post them if some occurred?
Greetings - Phil
"$message.dst_ip" is a literal string, $message.dst_ip is a constant pointing to the content of the “dst_ip” field of the current message.
Lol, I never noticed, that the reference was quoted, oops, my bad :smiley:
Hi Phil , Jochen
:slight_smile:
Final working code as shown below
has_field(“src_ip”) && has_field(“dst_ip”)
let src_ip_comma = concat(to_string($message.src_ip), “-”);
let src_dst = concat(src_ip_comma,to_string($message.dst_ip));
set_field(field:“src_dst_ip”, value: src_dst);
Output
src_dst_ip
192.168.96.1-192.168.96.141
