Pipeline, concat
Hi Guys,
I would like to create a pipleni what combinate two fields to the another.
But I do not know why it is not working…
Pls help,
rule “Rule”
has_field(“Rule”) AND has_field(“MID”)
let part_MID = concat(to_string($message.MID),to_string(" ("));
let part_Rule = concat(to_string($message.Rule),to_string(")"));
let Riport = concat(part_MID,part_Rule);
set_field(“Riport”,Riport);
you can find a working sample in the documentation:
http://docs.graylog.org/en/2.4/pages/pipelines/functions.html#concat
you might need to escape some characters or provide more information.
HI,
Thanks, I solved it half…
rule “Combine src and dst field”
has_field(“source”) && has_field(“level”)
let src_ip_comma = concat(to_string($message.source), “-”);
let src_dst = concat(src_ip_comma,to_string($message.level));
set_field(field:“src_dst_ip”, value: src_dst);
Like this, but if the value is not IP it is not working…any idea?
I modified like this, but not working…and I do not why.
Any Idea?
has_field(“From”) && has_field(“MID”)
let src_ip_comma = concat(to_string($message.From), “-”);
//From is an email address
let src_dst = concat(src_ip_comma,to_string($message.MID));
//MID is a Mail ID, 6 number , 888888
Here is my working version:
rule “URL”
has_field(“Domain”) && has_field(“Path”)
let URL = concat(to_string($message.Domain), to_string($message.Path));
set_field(“URL”, URL);
If the fileds you are concatenating are created by Graylog, please ensure that “Pipeline Processor” comes after “Message Filter Chain” in this config.
