Pipeline Rules not working
Please can someone help fix this code…It isnt bringing the field amongst the fields to be searched and it didnt throw any error. what am i getting wrong in the syntax?
rule "User Created"
  has_field("externalId == 4769")
 set_field(field:"UCreated", value: "Successful");
Ensure that the order of processing in Configuration is properly set.
Try if the below works:
rule "User Created"
	((has_field("externalId") AND (to_string($message.externalId) == "4769"))
	set_field("UCreated", "Successful");
Check the Simulator.
Thanks, it worked perfectly well. I tried the code below:
rule "User Created"
	((has_field("externalId") AND (to_string($message.externalId) == "4769")))
