Pipeline - Field not showing
Pls what am i getting wrong? Am still not seeing the “join” field amongst my search fields. Having in mind that I used a “copy input” extractor
rule "Join_test"
has_field("externalId")
let Name_join = concat(to_string($message.externalId), "-");
set_field(field:"join", value: Name_join);
rule "Join_test"
  set_field("join", Name_join);
should work
Also make sure to check the order of your pipeline processors on the System / Configurations page.
Thanks…I fixed it.
Please add some details about what the problem was and how you’ve fixed it so that other users having a similar problem can profit from this topic.
The problem was stated above. So, i fixed it by changing the order in my “System -----> Configuration” to the figure shown below and i was able to view the new field I created and was also able to combine more fields into a single field.
this was exactly what i did…so my pipeline rule was correct all along.
