HI, all
I have this rule and it is working as expected
rule “MyRule”
true
debug(concat("=== facility: ", to_string($message.facility)));
I am getting the debug output
2024-05-15T21:27:41.513Z INFO [Function] PIPELINE DEBUG: === facility: local1
However when I configure this rule, i am not getting the debut output
rule “MyRule”
has_field(“facility”)
- OS Information: Linux Ubuntu 22.04 / Greylog 6.0.1
Thanks,
Obvious, but double-check that field facility is really present in the log messages.
Try something other than debug, e.g. set a new field in the message. Does that work?
Test requested:
This rule works as expected.
rule “MyRule”
true
debug(concat("=== facility: “, to_string($message.facility)));
set_field(“facility2”, $message.facility);
debug(concat(”=== facility2: ", to_string($message.facility2)));
I get this output
2024-05-16T12:48:52.855Z INFO [Function] PIPELINE DEBUG: === facility: daemon
2024-05-16T12:48:52.855Z INFO [Function] PIPELINE DEBUG: === facility2: daemon
But when using this rule, I am not getting any output
rule “MyRule”
Found my issue.
I made the wrong assumption and thought rules are executed in sequential order within the same stage. I have a previous rule that parse the JSON message received and map it into different fields.
The solution was to create 2 stages. Stage0 will only parse the JSON and Stage1 will do the subsequent tasks I want to perform based onf the facility field.
