Pipeline question
Hello,I have a stream, and i want to drop some event using pipeline.
  1. I create a pipeline and connect to my stream.
  2. Create two stage and two rule:
    rule “src_ip”
    true
    let mess = to_string($message.message);
    let parsed = grok(pattern: “%{IPV4:src_ip}”,value: mess);
    set_fields(parsed);
    rule “Remove”
    has_field(“src_ip”) &&
    cidr_match(“192.168.0.0/21”, to_ip($message.src_ip)) - for example
    drop_message();
  3. Copy RAW filebeats output to simulator:
Message would be dropped
The pipeline processor would drop such a message. That means that the message would not be stored , and would not be available for searches, alerts, outputs, or dashboards.
But if a launch filebeat to send logs - it’s not working.
he @MalinkinSA
what is your processing order in System > configuration?
Hello @jan
Pipeline Processor - enabled;
Order
Use drag and drop to change the execution order of the message processors.
AWS Instance Name Lookup
GeoIP Resolver
Pipeline Processor
Message Filter Chain
you might want to change the oder @MalinkinSA
message filter chain
pipeline processor
and disable aws dn geoip if you do not use that.
Many thanks, in test case that’s all ok.
