Hello Graylog Community. I have a pipeline processing a stream to drop messages containing specific source IPs. I expected that once the pipeline was kicked off, if I went into that stream I would be able to query those IPs which I removed via the pipeline processing rules and get no results. However I still get results. Sample pipeline rule:
rule "Vuln Scanner IP removal"
When
has_field(“src_ip=10.x”) ||
drop_message();
I expect the stream to no longer have any of these specific source IPs since it should be dropping those messages. The rule is setup as stage 0 for the pipeline.
Any recommendations greatly appreciated.
