Pipeline doesn't work
Hi Guys,
I need to drop all the messages which contains a certain IP and i’ve wrote the following rule:
rule “False_Positive”
has_field(“message”) AND
contains(“192.168.1.78”,to_string($message.message))
drop_message();
the configuration is:
Processor Status
1 Message Filter Chain active
2 Pipeline Processor active
3 GeoIP Resolver active
Unfortunately nothing is happen and the logs which contains the above IP are still on my dashboard.
Any idea where the problem could be?
Laurentiu
use debug() to see what is going on. For instance:
    debug("-- Start of  FP THEN --");
    let izzittrue = concat("~~~IP was found: ", to_string(contains("192.168.2.182",to_string($message.message))));
    debug(izzittrue);
    debug($message.message);
    drop_message();
Monitor with:
You may need to swap your parameters around, as per the documentation:
https://docs.graylog.org/en/latest/pages/pipelines/functions.html#contains
yes - swap is one option - the other - name the parameters…
contains(search: “192.168.1.78”, value:to_string($message.message))
It seems that this is the good solution. Thanks
