Persistence not working
Persistent not working new setup docker, volumes are not created in the path listed in the yml file. They are created in var/lib/docker. Every time I do docker-compose down and restart the data in the logs is gone. The settings remain but the log data is gone.
  • OS Information: ubuntu 22.04.1 LTS
  • Package Version: latest docker, graylog 5.0, mongo 5.0.13, opensearch 2.4.0
    here is the yml file
version: ‘3.8’
services:
mongo:
image: mongo:5.0.13
volumes:
  • mongo_data:/data/db
    networks:
    - graylog
    restart: always
opensearch:
image: opensearchproject/opensearch:2.4.0
volumes:
  • op_data:/usr/share/graylog/openseach
    environment:
  • OPENSEARCH_JAVA_OPTS=-Xms512m -Xmx512m
  • bootstrap.memory_lock=true
  • discovery.type=single-node
  • action.auto_create_index=false
  • plugins.security.ssl.http.enabled=false
  • plugins.security.disabled=true
  • hostname:opensearch
ulimits:
memlock:
hard: -1
soft: -1
networks:
  • graylog
    restart: always
graylog:
image: graylog/graylog:5.0
volumes:
  • graylog_data:/usr/share/graylog/data
  • graylog_journal:/usr/share/graylog/data/journal
  • “graylogconfig:/usr/share/graylog/data/config”
    environment:
CHANGE ME (must be at least 16 characters)!
  • GRAYLOG_PASSWORD_SECRET=AlfaOmega1graylog
  • GRAYLOG_ALLOW_LEADING_WILDCARD_SEARCHES=true
  • GRAYLOG_ALLOW_HIGHLIGHTING=true
Password: admin
  • GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
- GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9000
  • GRAYLOG_ELASTICSEARCH_HOSTS=http://opensearch:9200
  • GRAYLOG_HTTP_EXTERNAL_URI=
  • TZ=America/New_York
  • GRAYLOG_ROOT_TIMEZONE=America/New_York
  • GRAYLOG_TIMEZONE=America/New_York
  • GRAYLOG_TRANSPORT_EMAIL_ENABLED=true
  • GRAYLOG_TRANSPORT_EMAIL_HOSTNAME=100.100.1.4
  • GRAYLOG_TRANSPORT_EMAIL_PORT=25
  • GRAYLOG_TRANSPORT_EMAIL_USE_AUTH=false
  • GRAYLOG_TRANSPORT_EMAIL_USE_TLS=false
  • GRAYLOG_TRANSPORT_EMAIL_USE_SSL=false
    entrypoint: /usr/bin/tini – wait-for-it opensearch:9200 – /docker-entrypoint.sh
    networks:
  • graylog
Links MongoDB with OpenSearch.
links:
- mongo:mongo
- opensearch
restart: always
depends_on:
- opensearch
- mongo
ports:
Graylog web interface and REST API
  • 9000:9000
Syslog TCP
  • 1514:1514
Syslog UDP
  • 1514:1514/udp
GELF TCP
  • 12201:12201
GELF UDP
  • 12201:12201/udp
CEF UPD
  • 5555:5555/udp
    networks:
    graylog:
    driver: bridge
    volumes:
    mongo_data:
driver: local
op_data:
driver: local
graylog_data:
driver: local
graylog_journal:
driver: local
graylogconfig:
driver: local
I have tried different syntaxes, also chmod 777 the desired base path in the yml file.
I am new to docker. This is my second setup. I can’t figure out why the persistence is not working, and the volumes are not created outside the docker path. Any help would be great.
Thank you,
I got it figured out.
