Docker persistent volume issue
Hi all,
I’m trying to get Graylog up and running using docker compose. I’ve started with a basic config here which works fine:
https://docs.graylog.org/en/4.0/pages/installation/docker.html
When I try and setup persistent data, I’m running into issues. I’ve created a directory here for all the graylog data on my Unraid system “/mnt/user/graylog/”
From there I’ve added the following items to my docker compose:
volumes:
- /mnt/user/graylog/mongo_data:/data/db
volumes:
- /mnt/user/graylog/es_data:/usr/share/elasticsearch/data
volumes:
- /mnt/user/graylog/graylog_data:/usr/share/graylog/data
The mongo and elasticsearch volumes are working fine. When I add the graylog volume I get the following error:
“Couldn’t load configuration: Properties file /usr/share/graylog/data/config/graylog.conf doesn’t exist”
After some reading it looks like something to do with UID/GID but I can’t seem to figure it out. Any help would be much appreciated.
Thanks!
