Graylog container-persistence not working on absolute path
Hello Community,
I got a problem with making my Docker-Containter-Setup persistent.
I put in a lot of effort solving it myself, but this is my first real docker home network project, so bare with me please :slight_smile:
Description of your problem
My only problem is mounting volumes to specific, absolute paths only for the graylog image.
For Elasticsearch and Mongo it does work
Description of steps you’ve taken to attempt to solve the issue
When it didn’t work I started with making sure it worked without mounting volumes from the containers. It did.
Then I tested for each of the 3 images seperately. Narrowed it down to “graylog/graylog”
Then I tested using volume in docker’s default directory by defining volume like this:
- graylog_data:/usr/share/graylog/data/
instead of
- /dockvol/graylog/graylog_data:/usr/share/graylog/data
That worked also and data was written in `/var/lib/docker/volumes/graylog_graylog_data/_data
Then I compared permissions of
and
/dockvol/graylog/graylog_data/
with no success, although I believe that the problem must be somewhere here :smiley:
Finally I added
“GRAYLOG_SERVER_JAVA_OPTS=-Dlog4j2.debug=true” to the graylog-service to get some Debugging info.
Environmental information
Operating system information
Ubuntu Server
Distributor ID: Ubuntu
Description:    Ubuntu 20.04.4 LTS
Release:        20.04
Codename:       focal
Package versions
REPOSITORY                                          TAG       IMAGE ID       CREATED         SIZE
graylog/graylog                                     4.2       3d389cc20dde   6 weeks ago     473MB
mongo                                               4.2       5db1c04860da   6 weeks ago     388MB
docker.elastic.co/elasticsearch/elasticsearch-oss   7.10.2    b313026e6fbd   17 months ago   699MB
Service logs, configuration, and environment variables
docker-compose.yml:
version: '3'
services:
    mongo:
      image: mongo:4.2
      networks:
        - graylog
      volumes:
        - /dockvol/graylog/mongodb:/data/db
    # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
    elasticsearch:
      image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
      volumes:
        - /dockvol/graylog/es_data:/usr/share/elasticsearch/data
      environment:
        - http.host=0.0.0.0
        - transport.host=localhost
        - network.host=0.0.0.0
        - "ES_JAVA_OPTS=-Dlog4j2.formatMsgNoLookups=true -Xms512m -Xmx512m"
      ulimits:
        memlock:
          soft: -1
          hard: -1
      networks:
        - graylog
    graylog:
      image: graylog/graylog:4.2
      user: "1100"
      volumes:
        #- graylog_data:/usr/share/graylog/data/
      environment:
        - GRAYLOG_PASSWORD_SECRET=XXX
        # Password: admin
        - GRAYLOG_ROOT_PASSWORD_SHA2=XXX
        - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
        - "GRAYLOG_SERVER_JAVA_OPTS=-Dlog4j2.debug=true"
      entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 --  /docker-entrypoint.sh
      networks:
        - graylog
      restart: always
      depends_on:
        - mongo
        - elasticsearch
      ports:
        - 9000:9000
        # Syslog TCP
        - 1514:1514
        # Syslog UDP
        - 1514:1514/udp
        # GELF TCP
        - 12201:12201
        # GELF UDP
        - 12201:12201/udp
networks:
    graylog:
      driver: bridge
volumes:
    graylog_data:
directory permissions:
root@asdf# ll /var/lib/docker/volumes/graylog_graylog_data/_data/
total 36
drwxr-x--- 9 graylog graylog 4096 Jun 15 22:33 ./
drwx-----x 3 root    root    4096 Jun 15 22:33 ../
drwxr-x--- 2 graylog graylog 4096 Jun 15 22:33 config/
drwxr-xr-x 2 graylog graylog 4096 Jun 15 22:33 contentpacks/
drwxr-x--- 2 graylog graylog 4096 May  4 18:18 data/
drwxr-x--- 3 graylog graylog 4096 Jun 17 10:37 journal/
drwxr-xr-x 2 graylog graylog 4096 Jun 17 10:37 libnative/
drwxr-x--- 2 graylog graylog 4096 May  4 18:18 log/
drwxr-x--- 2 graylog graylog 4096 May  4 18:18 plugin/
root@asdf ll /dockvol/graylog/graylog_data/
total 28
drwxr-xr-x 7 graylog graylog 4096 Jun 15 22:15 ./
drwxr-xr-x 5 root    root    4096 Jun 15 22:39 ../
drwxr-xr-x 2 graylog graylog 4096 Jun 15 22:30 config/
drwxr-xr-x 2 graylog graylog 4096 Jun 15 22:15 contentpacks/
drwxr-xr-x 2 graylog graylog 4096 Jun 15 22:15 journal/
drwxr-xr-x 2 graylog graylog 4096 Jun 15 22:15 log/
drwxr-xr-x 2 graylog graylog 4096 Jun 15 22:15 plugin/
users:
root@asdf# grep graylog /etc/passwd
graylog:x:1100:1100:Graylog,,,:/home/graylog:/bin/bash
root@asdf# grep graylog /etc/group
graylog:x:1100:
and (imho) the relevant error message:
graylog_1        | DEBUG StatusLogger Catching
graylog_1        |  java.io.FileNotFoundException: /usr/share/graylog/data/config/log4j2.xml (No such file or directory)
graylog_1        |      at java.io.FileInputStream.open0(Native Method)
graylog_1        |      at java.io.FileInputStream.open(FileInputStream.java:195)
graylog_1        |      at java.io.FileInputStream.<init>(FileInputStream.java:138)
graylog_1        |      at org.apache.logging.log4j.core.config.ConfigurationFactory.getInputFromString(ConfigurationFactory.java:370)
graylog_1        |      at org.apache.logging.log4j.core.config.ConfigurationFactory$Factory.getConfiguration(ConfigurationFactory.java:512)
graylog_1        |      at org.apache.logging.log4j.core.config.ConfigurationFactory$Factory.getConfiguration(ConfigurationFactory.java:498)
graylog_1        |      at org.apache.logging.log4j.core.config.ConfigurationFactory$Factory.getConfiguration(ConfigurationFactory.java:422)
graylog_1        |      at org.apache.logging.log4j.core.config.ConfigurationFactory.getConfiguration(ConfigurationFactory.java:323)
graylog_1        |      at org.apache.logging.log4j.core.LoggerContext.reconfigure(LoggerContext.java:695)
graylog_1        |      at org.apache.logging.log4j.core.LoggerContext.reconfigure(LoggerContext.java:716)
graylog_1        |      at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:270)
graylog_1        |      at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:155)
graylog_1        |      at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:47)
graylog_1        |      at org.apache.logging.log4j.LogManager.getContext(LogManager.java:196)
graylog_1        |      at org.apache.logging.log4j.spi.AbstractLoggerAdapter.getContext(AbstractLoggerAdapter.java:137)
graylog_1        |      at org.apache.logging.slf4j.Log4jLoggerFactory.getContext(Log4jLoggerFactory.java:55)
graylog_1        |      at org.apache.logging.log4j.spi.AbstractLoggerAdapter.getLogger(AbstractLoggerAdapter.java:47)
graylog_1        |      at org.apache.logging.slf4j.Log4jLoggerFactory.getLogger(Log4jLoggerFactory.java:33)
graylog_1        |      at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:363)
graylog_1        |      at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:388)
graylog_1        |      at org.graylog2.bootstrap.CmdLineTool.<clinit>(CmdLineTool.java:106)
graylog_1        |      at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
graylog_1        |      at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
graylog_1        |      at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
graylog_1        |      at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
graylog_1        |      at com.github.rvesse.airline.parser.ParserUtil.createInstance(ParserUtil.java:39)
graylog_1        |      at com.github.rvesse.airline.DefaultCommandFactory.createInstance(DefaultCommandFactory.java:25)
graylog_1        |      at com.github.rvesse.airline.parser.ParserUtil.createInstance(ParserUtil.java:94)
graylog_1        |      at com.github.rvesse.airline.parser.ParseResult.getCommand(ParseResult.java:114)
graylog_1        |      at com.github.rvesse.airline.parser.command.CliParser.parse(CliParser.java:54)
graylog_1        |      at com.github.rvesse.airline.Cli.parse(Cli.java:127)
graylog_1        |      at com.github.rvesse.airline.Cli.parse(Cli.java:113)
graylog_1        |      at org.graylog2.bootstrap.Main.main(Main.java:43)
graylog_1        | ERROR StatusLogger Reconfiguration failed: No configuration found for '70dea4e' at 'null' in 'null'
graylog_1        | DEBUG StatusLogger Shutdown hook enabled. Registering a new one.
Thanks for anyone who took the effort to read and tries to help.
Regards
Chris
Hello @SofaKingBoring && Welcome
I’m also playing around with Docker/Docker-Compose. Just learning the in’s & Outs of this software.
I have not used the absolute path for a image, I thought Docker took care of that already? After working with this setup the one thing I like best was the quick way of upgrading the software by adjusting the image from the yaml file then restarting. From the logs it looks like Graylog can not find
the log4j2.xml file. this should be in the home directory/container.
Not sure what the issue could be but I can show you my compose file, perhaps that might help.
This is on Ubuntu 20.0 just for testing out Enterprise stuff.
yaml file
version: '3'
services:
  mongodb:
    image: mongo:4.4
    network_mode: bridge
   # DB in share for persistence
    volumes:
      - mongo_data:/data/db
   # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/6.6/docker.html
  elasticsearch:
    image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2-amd64
    # image: opensearchproject/opensearch:1.3.2
    #data folder in share for persistence
    volumes:
    environment:
      - http.host=0.0.0.0
      #- network.publish_host=10.200.6.28
    ulimits:
      memlock:
        soft: -1
        hard: -1
    mem_limit: 1g
  graylog:
    image: graylog/graylog-enterprise:4.3-jre11
    dns:
      - 8.8.8.8
      - 8.8.4.4
   # journal and config directories in local NFS share for persistence
    volumes:
       - graylog_bin:/usr/share/graylog/bin
       - graylog_data:/usr/share/graylog/data/config
       - graylog_log:/usr/share/graylog/data/log
       - graylog_plugin:/usr/share/graylog/data/plugin
       - graylog_content:/usr/share/graylog/data/contentpacks
      # Mount local configuration directory into Docker container
    environment:
      # Container time Zone
      - TZ=America/Chicago
      - GRAYLOG_PASSWORD_SECRET=pJod1TRZpiuu2XLTZuifjy7cLpetnwZf6Q79HW2nonDhN
      # Password: admin
      - GRAYLOG_ROOT_PASSWORD_SHA2=ef92b778bafe771e89911881f383d4473e94f
      - GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9000
      - GRAYLOG_HTTP_EXTERNAL_URI=http://10.10.10.10:9000/
      - GRAYLOG_ROOT_TIMEZONE=America/Chicago
      - GRAYLOG_ROOT_EMAIL=greg.smith@enseva.com
      - GRAYLOG_HTTP_PUBLISH_URI=http://10.10.10.10:9000/
      - GRAYLOG_TRANSPORT_EMAIL_PROTOCOL=smtp
      - GRAYLOG_HTTP_ENABLE_CORS=true
      - GRAYLOG_TRANSPORT_EMAIL_WEB_INTERFACE_URL=http://10.10.10.10:9000/
      - GRAYLOG_TRANSPORT_EMAIL_HOSTNAME=10.10.10.10
      - GRAYLOG_TRANSPORT_EMAIL_ENABLED=true
      - GRAYLOG_TRANSPORT_EMAIL_PORT=25
      - GRAYLOG_TRANSPORT_EMAIL_USE_AUTH=false
      - GRAYLOG_TRANSPORT_EMAIL_USE_TLS=false
      - GRAYLOG_TRANSPORT_EMAIL_USE_SSL=false
      - GRAYLOG_TRANSPORT_FROM_EMAIL=root@localhost
      - GRAYLOG_TRANSPORT_SUBJECT_PREFIX=[graylog]
      - GRAYLOG_REPORT_DISABLE_SANDBOX=true
      - GRAYLOG_REPORT_RENDER_URI=http://10.10.10.10:9000
      # - GRAYLOG_REPORT_USER=graylog-report
      - GRAYLOG_REPORT_RENDER_ENGINE_PORT=9515
    links:
      - mongodb:mongo
      - elasticsearch
    depends_on:
      - mongodb
      - elasticsearch
    ports:
      - 9000:9000
      # Syslog TCP
      - 8514:8514
      # Elasticsearch
      - 9200:9200
      - 9300:9300
      # Syslog UDP
      - 8514:8514/udp
      # GELF TCP
      #- 12201:12201
      # GELF UDP
      #- 12201:12201/udp
      # Reports
      - 9515:9515
      - 9515:9515/udp
      # beats
      - 5044:5044
      # email
      - 25:25
      - 25:25/udp
      # web
      - 80:80
      - 443:443
      - 21:21
      # Forwarder
      - 13302:13302
      - 13301:13301
      # keycloak
      - 8443:8443
      # packetbeat
      - 5055:5055
#Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
volumes:
  mongo_data:
    driver: local
  es_data:
    driver: local
  graylog_journal:
 driver: local
  graylog_bin:
    driver: local
  graylog_data:
    driver: local
  graylog_log:
    driver: local
  graylog_plugin:
    driver: local
  graylog_content:
    driver: local
graylog/graylog-enterprise                          4.3-jre11      ec6db44b0465   4 weeks ago     841MB
mongo                                               4.4            aa61e4b09cef   6 weeks ago     438MB
docker.elastic.co/elasticsearch/elasticsearch-oss   7.10.2-amd64   b313026e6fbd   17 months ago   699MB
The rest looks like you post ( passwd, etc…)
Yes it’s true that it is missing the log4j2.xml, but it should be writing it there at startup.
At least that’s what’s happening in the “default” folders /var/lib/docker, if I don’t use the absolute path as given above.
If noone else has an idea I will first try to get 4.3 running with opensearch and then get back to this issue.
I still hope someone will have an insight here :slight_smile:
