Password reset RHEL 7
Old administration has a Graylog Server that cant be accessed. The new admins do not know the credentials to login via CLI or Web interface. I tried the reset using “e” but it still wants a username and password.
  • OS Information: RHEL 7
  • Package Version: Not sure
    cant access graylog to get logs.
Just need advice on how to bypass the username and password on the “e” screen. Not sure its even possible.
Can you clarify what “e” means in this context?
If you can access and modify it, you can change the root (username: admin) graylog password via server.conf using the root_password_sha2 configuration parameter.
edit to add: if you are asking about resetting a RHEL password, that is unfortunately outside the scope of this forum.
We were able to recover the root credentials and go into the serv.conf and change the password. Thanks for the response.
