I have configured the Graylog v3.0.2+1686930 OVA with Palo Alto Networks Input by installing graylog-integrations-plugins .
Created a new Input using “Palo Alto Networks Input (TCP)” and configured the Firewall to send logs on port 5555. I can see the message is receiving in the input as
Hey there,
check if time and timezone is correct. especially if you use the ova template the system time may have to be corrected. please also check the time in server.conf of graylog.
Timezone is correct with my timezone, I have changed the Format BSD to IETF. Now I start receiving the log on Palo Alto Software Version 8.1.
I have configured the same for Palo Alto Software Version 8.0 but no log is showing but message is receiving in the input as count is showing. I have done the reference of official Palo Alto Networks log fields documentation that that version and customize the mappings , but no result
