New installation on AlmaLinux release 8.8
Followed the basic install instructions - and things mostly worked as expected. Graylog is installed and operating. For my use case, trying to now add graylog-enterprise - However, it did not end well.
# sudo yum install graylog-enterprise
Last metadata expiration check: 2:16:48 ago on Fri Sep 8 07:19:30 2023.
Error:
Problem: problem with installed package graylog-server-5.1.5-1.x86_64
- package graylog-server-5.1.5-1.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.0-1.beta.1.x86_64
- package graylog-server-5.1.0-1.beta.1.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.0-2.beta.2.x86_64
- package graylog-server-5.1.0-2.beta.2.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.0-3.beta.3.x86_64
- package graylog-server-5.1.0-3.beta.3.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.0-4.rc.1.x86_64
- package graylog-server-5.1.0-4.rc.1.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.0-5.rc.2.x86_64
- package graylog-server-5.1.0-5.rc.2.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.0-6.x86_64
- package graylog-server-5.1.0-6.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.1-1.x86_64
- package graylog-server-5.1.1-1.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.2-1.x86_64
- package graylog-server-5.1.2-1.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.3-1.x86_64
- package graylog-server-5.1.3-1.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- package graylog-enterprise-5.1.5-1.x86_64 conflicts with graylog-server provided by graylog-server-5.1.4-1.x86_64
- package graylog-server-5.1.4-1.x86_64 conflicts with graylog-enterprise provided by graylog-enterprise-5.1.5-1.x86_64
- cannot install the best candidate for the job
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
I initially assumed the enterprise package would add the additional capabilities. However, it appears that it might be a replacement package. Assuming that is the case, what is the migration path to move from community to enterprise without reconfiguring everything?
Worst case scenario, if I need to reinstall, how is the Cluster ID generated? Will this change, because I just submitted a license request using the current ID.
