Hi there,
since i got a problem which i think cant get solved by the provided pipeline rule functions, i decided to write my own plugin.
I used this tutorial for setting up my workspace.
Everything seemd to be good, at least until i copied my .jar into the plugin folder and tried to restart graylog.
The errors that are thrown are this:
oivsvmw593 graylog-server[19636]: Caused by: java.lang.ClassNotFoundException: org.graylog.plugins.pipelineprocessor.ast.functions.AbstractFunction
graylog-server[19636]: at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
graylog-server[19636]: at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
graylog-server[19636]: at java.net.FactoryURLClassLoader.loadClass(URLClassLoader.java:814)
graylog-server[19636]: at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
my Function looks like this:
package com.burda.plugins.domainsplit;
import org.graylog.plugins.pipelineprocessor.EvaluationContext;
import org.graylog.plugins.pipelineprocessor.ast.functions.AbstractFunction;
import org.graylog.plugins.pipelineprocessor.ast.functions.FunctionArgs;
import org.graylog.plugins.pipelineprocessor.ast.functions.FunctionDescriptor;
import org.graylog.plugins.pipelineprocessor.ast.functions.ParameterDescriptor;
import java.util.Arrays;
import java.util.List;
public class DomainSplitFunction extends AbstractFunction<String[]> {
public static final String NAME = "domain_split";
private final ParameterDescriptor<String, String> value;
private final List<String> secondLevel = Arrays.asList("2000", "ab", "ac");
public DomainSplitFunction() {
value = ParameterDescriptor.string("value")
.description("The Domain String to be split")
.build();
@Override
public String[] evaluate(FunctionArgs args, EvaluationContext context) {
String domain = value.required(args, context);
if(domain == null) {
return null;
String[] split = domain.split("\\.");
String[] domains = new String[3];
int count = split.length-1;
String subDom = "";
try {
if(secondLevel.contains(split[count-1])) {
domains[0] = split[count - 1] + "." + split[count];
count = count - 2;
} else {
domains[0] = split[count];
count = count - 1;
domains[1] = split[count];
count = count - 1;
for(; count >= 0; count--) {
if(subDom.equals("")) {
subDom = split[count];
} else {
subDom = split[count].concat("."+subDom);
} catch (Exception e) {
System.out.println("Error with Domain String");
return null;
domains[2] = subDom;
return domains;
@Override
public FunctionDescriptor<String[]> descriptor() {
return FunctionDescriptor.<String[]>builder()
.name(NAME)
.params(value)
.returnType(String[].class)
.description("Splits given Domain String into an Array with Top Level (0), Domain (1) and Subdomain (2)")
.build();
The FunctioModule looks like this:
import com.google.inject.Binder;
import org.graylog2.plugin.PluginConfigBean;
import org.graylog2.plugin.PluginModule;
import java.util.Collections;
import java.util.Set;
import static org.graylog.plugins.pipelineprocessor.functions.ProcessorFunctionsModule.addMessageProcessorFunction;
import static org.graylog.plugins.pipelineprocessor.functions.ProcessorFunctionsModule.processorFunctionBinder;
public class DomainSplitFunctionModule extends PluginModule {
@Override
public Set<? extends PluginConfigBean> getConfigBeans() {
return Collections.emptySet();
@Override
protected void configure() {
* Register your plugin types here.
* Examples:
* addMessageInput(Class<? extends MessageInput>);
* addMessageFilter(Class<? extends MessageFilter>);
* addMessageOutput(Class<? extends MessageOutput>);
* addPeriodical(Class<? extends Periodical>);
* addAlarmCallback(Class<? extends AlarmCallback>);
* addInitializer(Class<? extends Service>);
* addRestResource(Class<? extends PluginRestResource>);
* Add all configuration beans returned by getConfigBeans():
* addConfigBeans();
addMessageProcessorFunction(DomainSplitFunction.NAME, DomainSplitFunction.class);
protected void addMessageProcessorFunction(String name, Class<DomainSplitFunction> domainSplitFunctionClass) {
addMessageProcessorFunction(binder(), name, domainSplitFunctionClass);
public static void addMessageProcessorFunction(Binder binder, String name, Class<DomainSplitFunction> domainSplitFunctionClass) {
processorFunctionBinder(binder).addBinding(name).to(domainSplitFunctionClass);
I had Problems with editing the FunctionModule like the tutorial did it… It seems like some functions are not working anymore
Greetings
Merasil
