Threatintel graylog plugin wont work with graylog 2.4.4
graylog :2.4.4
threatintel: 2.4.4
i get below error
Exception in thread "main" java.lang.NoClassDefFoundError: org/graylog/plugins/pipelineprocessor/ast/functions/AbstractFunction
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
	at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
	at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
	at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
	at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
	at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:335)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	at org.graylog.plugins.threatintel.ThreatIntelPluginModule.configure(ThreatIntelPluginModule.java:48)
	at com.google.inject.AbstractModule.configure(AbstractModule.java:62)
	at com.google.inject.spi.Elements$RecordingBinder.install(Elements.java:340)
	at org.graylog2.shared.bindings.PluginBindings.configure(PluginBindings.java:51)
	at com.google.inject.spi.Elements.getElements(Elements.java:110)
	at com.google.inject.internal.InjectorShell$Builder.build(InjectorShell.java:138)
	at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:104)
	at com.google.inject.Guice.createInjector(Guice.java:99)
	at org.graylog2.shared.bindings.GuiceInjectorHolder.createInjector(GuiceInjectorHolder.java:34)
	at org.graylog2.bootstrap.CmdLineTool.setupInjector(CmdLineTool.java:379)
	at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:193)
	at org.graylog2.bootstrap.Main.main(Main.java:44)
Caused by: java.lang.ClassNotFoundException: org.graylog.plugins.pipelineprocessor.ast.functions.AbstractFunction
	at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
	... 50 more
Process finished with exit code 1
It looks like you’re missing the Graylog Pipeline Processor plugin in your Graylog node.
The plugin is being distributed by default as part of Graylog 2.4.4, so make sure to check the plugin directory and the logs of your Graylog nodes.
