I’m using latest Graylog version. Now i need to create my custom plugin in order to create a pipeline rule function. I’m develpoing using java 11.
What I have to do to complete my task?
Gianluca
Gianluca
I’m assuming your question is How To create a plugin? if so I would use this documentation.
As for pipeline I would use this documentation.
https://docs.graylog.org/v1/docs/pipelines
Hope that helps.
Hi @gsmith ,
Thanks for your suggestion.
Do you know if there is a problem if use java 11 to develop it?
Correct me if I’m wrong but are you using Deb OS? if so that requires openjdk-11-jre-headless installed. I’m assuming that was the version of JAVA your using?
Not that I know of yet, but you can find out here.
Thanks for your help
I will try to follow your suggestion
