We are working on integrating Openshift container 4.6 to Graylog, we successfully managed to stream logs from container to Graylog using non-SSL. We would like to enable SSL. Container team says they enable it, still I am seeing at Graylog side as non-SSL. I would to hear if you have succeed in enabling SSL communication between container 4.6 or above and Graylog. I was told they need key at Openshift cluster side which is also not clear which key, we disable client auth so we don’t have key to share. Let me know if you have any queries further.
Problem resolved at OpenShift configuration side.
