How to configure my Graylog setup based on Container with https
I am trying to implement SSL in my current graylog setup which is running on container based. We have docker compose file to create this whole setup. I got this document (The Web Interface) but not able to understand where I need to start and what settings to be done in the container.
My goal is to access graylog web interface like https://graylog-env.mydomain.com
Please help me on this with detailed steps :slight_smile:
Hello @I_am_winner,
Have a read through this guide and come back with questions, should you have any.
@Wine_Merchant
I have gone through still I am not sure on the below points
  1. Is Java key store required? why?
  2. I didn’t find this path /etc/graylog/server/server.conf as I am using graylog using container
  3. I need the steps for container based graylog server
Hey @I_am_winner,
You will need to use environment variables instead of editing the server.conf file directly.
GRAYLOG_HTTP_TLS_CERT_FILE: /usr/share/graylog/data/config/cert.pem
GRAYLOG_HTTP_TLS_KEY_FILE: /usr/share/graylog/data/config/privkey.pem
GRAYLOG_SERVER_JAVA_OPTS:"Djavax.net.ssl.trustStore=/usr/share/graylog/data/config/cacerts -Djavax.net.ssl.trustStorePassword=changeit"
You can persist the paths to those certs and key store by using volumes.
 volumes:
      - "graylog_data:/usr/share/graylog/data/data"
      - "graylog_journal:/usr/share/graylog/data/journal"
      - "graylog_config:/usr/share/graylog/data/config"
The keystore is required for the Graylog nodes to make api calls to each other and themselves. The CA or node cert should be added to the keystore.
