symbol-c
(Symbol C)
April 17, 2019, 8:49am
1
Hi, i have recently setup graylog and i’m using nxlog as my collector,
everything seems to be working fine except nxlog is not sending logs to the graylog server,
i have checked nxlog logs and this is the error
2019-04-16 11:51:08 ERROR failed to open C:\Users\s.chimere\Desktop\GRAYLOG; Access is denied
C:\Users\s.chimere\Desktop\GRAYLOG this is where i have my test logs that i want to send to the graylog server
Please can anyone help.
Karlis
April 17, 2019, 10:54am
2
It means, account under which nxlog service is running cannot access C:\Users\s.chimere\Desktop\GRAYLOG.
symbol-c
(Symbol C)
April 17, 2019, 3:43pm
3
okay thank you
so the graylog server and the machine with the sidecar need to be in the same domain. yes ?
Karlis
April 18, 2019, 6:26am
4
No, this is something about permissions on computer with nxlog installed. BTW, user profile, including desktop, is not the best place for test files, Windows can create some mess with permissions there. Make some folder under C:\ and place test logs there and see if something changes.
symbol-c
(Symbol C)
April 18, 2019, 8:11am
5
Alright thanks,
will try and revert
symbol-c
(Symbol C)
April 18, 2019, 3:53pm
6
i think i have this sorted out but im not receiving logs,
i am trying to pull a couple of .txt logs from computer to the server
i’m using beats input and below is my nxlog config
Moduledir %ROOT%\modules
CacheDir %ROOT%\data
Pidfile %ROOT%\data\nxlog.pid
SpoolDir %ROOT%\data
LogFile %ROOT%\data\nxlog.log
LogLevel INFO
Module xm_fileop
When @daily
Exec file_cycle('%ROOT%\data\nxlog.log', 7);
Module xm_gelf
# Avoid truncation of the short_message field to 64 characters.
ShortMessageLength 65536
Module im_msvistalog
PollInterval 1
SavePos True
ReadFromLast True
#Channel System
#<QueryXML>
# <QueryList>
# <Query Id='1'>
# <Select Path='Security'>*[System/Level=4]</Select>
# </Query>
# </QueryList>
#</QueryXML>
Module im_file
File 'C:\GRAYLOG'
Module im_file
File "C:\GRAYLOG\log.txt"
PollInterval 1
SavePos True
ReadFromLast True
Recursive False
RenameCheck False
Exec $FileName = file_name(); # Send file name with each message
Module om_udp
Host 192.168.3.44
Port 5044
OutputType GELF
# These fields are needed for Graylog
$gl2_source_collector = '${sidecar.nodeId}';
$collector_node_id = '${sidecar.nodeName}';
Path eventlog => gelf
Path file => gelf
Karlis
April 23, 2019, 6:06am
8
Please make configuration as preformatted text, it’s very hard to read it now
symbol-c
(Symbol C)
April 23, 2019, 7:59am
10
LogLevel INFO
<Extension logrotate>
Module xm_fileop
<Schedule>
When @daily
</Schedule>
</Extension>
<Extension gelfExt>
Module xm_gelf
</Extension>
<Input eventlog>
PollInterval 1
SavePos True
ReadFromLast True
#Channel System
#<QueryXML>
# <QueryList>
# <Query Id='1'>
# </Query>
# </QueryList>
#</QueryXML>
</Input>
<Input error.log>
Module im_file
File 'C:\GRAYLOG'
</Input>
<Input file>
Module im_file
PollInterval 1
SavePos True
ReadFromLast True
Recursive False
RenameCheck False
</Input>
<Output gelf>
Module om_udp
Host 192.168.3.44
Port 5044
OutputType GELF
<Exec>
</Exec>
</Output>
<Route route-1>
</Route>
<Route route-2>
Path file => gelf
</Route>
symbol-c
(Symbol C)
April 23, 2019, 8:00am
11
sorry about that hope this is better ?
Karlis
April 23, 2019, 9:41am
12
Much better
Do you receive eventlogs from this computer?
Karlis
April 23, 2019, 9:48am
13
Try to use path without quotes (it is possible, since it contains no white spaces):
<Input file>
Module im_file
File C:\\GRAYLOG\\log.txt
symbol-c
(Symbol C)
April 23, 2019, 10:15am
14
i do not receive eventlogs and i have taken out the quotes and i am still not receiving any logs
anything else i can try
Karlis
April 23, 2019, 10:24am
15
OK, so problem is in nxlog output, not input. Or on graylog server. Do you receive something from other sources on graylog server?
symbol-c
(Symbol C)
April 23, 2019, 10:28am
16
the logs i want to send to my graylog server are on this computer
symbol-c
(Symbol C)
April 23, 2019, 11:03am
17
no i do not receive anything
i do not have any other sources setup
is my output config okay ? i’m not exactly sure of it
Karlis
April 23, 2019, 11:22am
18
Are you using Sidecar, not simply Nxlog?
symbol-c
(Symbol C)
April 23, 2019, 11:39am
19
i am using graylog sidecar
Karlis
April 23, 2019, 11:51am
20
I f so, all configuration should be in Sidecar, not nxlog.conf. I am not using it, can’t help, sorry.
symbol-c
(Symbol C)
April 23, 2019, 12:03pm
21
thanks, can you @ someone here you think can help me
Karlis
April 23, 2019, 12:10pm
22
I am not very active member of this community, no personal contacts here.
My suggestion is, read once more the documentation about Sidecar, try to configure it. If no luck, ask in new thread.
