Not able to install aws plugin in graylog
hi all im not able to install aws plugin in graylog.
I copied the jar file in the plugins dir and restarted the graylog server but it dosenot coming up in the system–>configuration.
Kindly suggest
did you check that you copied the plugin to the path that is needed in your installation?
http://docs.graylog.org/en/2.3/pages/configuration/file_location.html
Did you check the Graylog server.log?
Did you check if the choosen version is compatible with your Graylog version?
its fixed!! i was using wrong version plugin … all cool now
