MongoDB 5.0 upgrade guide, specify AVX support requirements
I’m testing Graylog 5 beta and MongoDB 5.
I’m following this document to upgrade from MongoDB 4.4 to 5.0.
When starting MongoDB I’m getting an error about MongoDB 5 and higher requiring AVX CPU support. My hypervisor doesn’t pass this CPU instruction through, so I need to update my VM config.
You may want to add a warning to Graylog’s MongoDB upgrade docs about MongoDB’s AVX requirements with the 5.x and higher releases. I can imagine people running Graylog/Mongo in virtual machines that don’t expose specific CPU instructions (like me) will need to know this.
Hey @lmm5247
Quick question on this, since it seams we might have same environment.
Have you posted this in GitHub?
The reason I stated this is because Graylog 5 Beta 4 is out today and it may help the dev’s identify this better on GitHub.
hey,
If you don’t mind that would be great, and thank you :+1:
I am getting mongodb avx error 132 which seems to be related to this. Looks like I need downgrade my mongodb level. Any ideas how I do this please?
Boomel
