If your referring to GitHub then I would suggest looking at Graylog.org instead.
As of today 11/10/2022
Graylog Beta 3
EDIT: TBH I’m waiting till the full release of Graylog 5.0 comes out, then I will do the upgrade from 4.3 to 5.0. Even thou it states 4.3 is able to support that version its basically for a smooth upgrade process but I would imaging if you insist on wanting Mongo 5.0 its possible but user beware also if this is a production environment I wouldn’t take the chance. Normally when its posted in the main Graylog documentations I know its good to go then.
Joining the discussion here because its specifically this case why I signed up
I think the problem here is that the documentation states that Graylog 4.3.X supports MongoDB up until 4.4, but for running Graylog 5 the documentation states:
Running Graylog 5.0 requires MongoDB 5.0 or 6.0.
So I am a bit puzzled how to actually do upgrades from Graylog 4.3.X to Graylog 5 as v4 only supports MongoDB up until 4.4 but for v5 I need MongoDB 5.X or 6.X - seems like a chicken-and-egg problem.
